Question about JBL S120PII Subwoofer
Power acoustic amp help
I hooked up my amp and it was working fine but my power and ground cables came off and now when i hook it back up it wont work. at first they only way to get it to work was to touch the rem. wire to the power cable but now that it only puts it in standby for a few sec. then the light turns off please somebody help.
    Genius:
  • 1,074 Answers
Probably you had cause the wire to ground out the set.causing the short out to damage the power supply take your set to a tech to check it.and possibly to repair.good luck.
Posted on Apr 14, 2007
SOURCE:
My power acoustic protection light stays on i got good ground and a good positive connection, no speakers or RCA's hooked up, what could it be
Are you fused close to the battery with a 30-50 amp fuse block?
Ground unit also to most closest suitable location!
Is your power wire undersized?
Check units fuses you may have blown one hooking it up!!
Good luck
Feb 15, 2011 | Power Acoustik LT-1920/2 Car Audio...
I have an AudioBahn A4004T Amp. It was working fine and then I had it sitting in my house for a few months. My cousin wants to use it in his car so he hooked the power cables up to his battery to see if it...
If you only hooked up the power and ground the amp will not turn on. You must also hook up the remote wire. This either can come from your radio, your fuses, or your power wire itself. If you hook it up to your radio then it will turn on when the radio is turned on. If your radio doesn't have a remote wire to amp then you can read your owners manual and hook it up to the radio fuse and when the radio turns on the amp will turn on. An lastly you can run a wore from your power wire to your remote plug in. But if you do this the nano will constantly be on if it is hooked up to the battery.
Dec 25, 2010 | AudioBahn A4004T Car Audio Amplifier
My power acoustic BAMF 2200 amp wont power subs
Check all of your connections, make sure your RCAs are hooked up correctly, and aren't pinched anywhere, make sure your subs are hooked up right, and making good contact, if the amp turns on and doesn't go into protect mode it should be alright. If you can't get it going, take it to an audio shop and have them test it...
Sep 17, 2009 | Car Audio & Video
I have a power acoustik ps2-2600 it went out this morning the red light was on i checked the ground it was fine when i unhook the remote or the audio cables it turns off if i hook up the audio alone it...
unhook all the cables including power let sit for 15 minutes and than hook up the ground rca cables remote and than power in that order with the car off and the battery unhooked that hook the battery up the amp went to protect mode to keep it from blowing i hope your amp isnt like some that only the factory can reset most amps arent and reset themselves
Apr 20, 2009 | Car Audio & Video
Smoking
Gee I would think that it is kind of obvious; your amp is blown. Just because it doesn't blow fuses doesn't mean much. If you hook the power up to the ground input and the ground to the power and then turn it on you pretty much toasted the amplifier. If you don't know why the amp is smoking, but you're trying to fix it yourself, you are basically telling me that you have no business doing so. I have been an installer for 15 years and even I am not dumb enough to try to fix a bad amplifier. Do everyone a REALLY big favor; stop messing around with something that you don't understand of have knowledge about before you hurt yourself.
Mar 16, 2008 | Legacy LA838 Car Audio Amplifier
No power to my legacy 600 watt car amp
Hmm...ive had this problem before and its always been either the remote wire, the rca cables or the ground. i would try hooking up the remote wire strait to the battery, if that doesnt work try to find a better place for the ground. maybe where your trunk latches. if that still doesnt work then i would try new rca cables.
Feb 13, 2008 | Car Audio & Video
Amp problems
did you run your 12+ to the battery? did you supply a sufficient ground of least 2x the size of the power lead?..did you hook up to the amp turn on lead and NOT the power antenna? model numbers of radio and amp would really be helpful...my email is troublerst@hotmail.com send me specifics and we will work it out
Nov 07, 2007 | Car Audio & Video
Red light
It sounds like the output transistors have failed. Disconnect everything from the amp except for the B+, ground and remote and turn the amp on. If it goes into protect, the amp is in need of repair. If you want to repair it yourself, email power acoustic for the schematic.
Oct 02, 2007 | Power Acoustik LT-980/2 Car Audio...
Amp not turning on
wouldn't be the first JL amp I saw fried...but there are some tests you can do. First of all, double check your fuses, they may appear to be fine, but sometimes they are blown even if you can't see it. Either blindly change them or test them for continuity with a digital multimeter. Also, disconnect the remote turnon and jump power directly over from the power wire to the remote terminal on the amp, if the amp powers on then you have to go double check your remote wire. Hope this helps.
Jul 27, 2007 | Kenwood Excelon KAC-X811D Car Audio...
JBL S120PII Subwoofer Logo
101 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
