Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water not flowing to Ice Maker
I replaced the ice maer and ice maker valve on the back of the refrigerator. The water still does not flow to the ice maker. I have a whirlpool refrigerator side by side about 8 years old. The model number is ed25pwxbn00. I am not sure what to do next. The only thing I can think of is the water line from the back of the freezer to the freezer is frozen.
Need help. Purchased the valve and Icemaker from e-bay. Vendor has sold many items with only a couple of complaints.
Need help.
Thanks
Dennis
  • Mrscariley Jan 28, 2009
    I have a the same problem. Do I have to take the ice maker out
    to use the blow dryer. Water is flowing to door for water - but is not flowing
    down tube to the ice trays.
  • 700 Answers
Thee water for the door and the water for the ice maker are thwo seperate lines going to the dispenser. you will have to thaw out the line first before you can get the ice maker to work again.
Posted on Jan 30, 2009
  • 115 Answers
Take your icemaker back out and take a hair dryer and blow it up the tube probably 10 to 15 mins
Posted on Dec 28, 2008
Ice maker not making ice
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valv
Sep 24, 2012 | Frigidaire Refrigerators
My ice maker stopped making ice...is there anything i can check myself to correct this problem
If the ice maker has completely stopped producing ice :-
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly:-
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Check this link for your knowledge:-
http://www.partselect.com/refrigerator+icemaker-no-ice+repair.htm
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker wont work
If the ice maker has completely stopped producing ice.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
If the ice maker is producing ice poorly.
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve. First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Mar 27, 2010 | Samsung RF265AA Bottom Freezer French Door...
Ice maker not making ice. do have water, no ice
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
Aug 29, 2009 | Kenmore Refrigerators
Refrigerator not making ice/freezing stuff
Hi..
In this problem you need to check this parts
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.Good luck.
ICmanServer
Jul 31, 2009 | Whirlpool Refrigerators
Will not make ice, water line is connected and turned on, and water dispenser works fine.
HI,
Jul 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water will not flow into ice maker
This could be 2 reasons for this The water control valve on back for the ice maker is defective or the thermostat inside the ice maker is defective. You can pore water into an empty ice maker and let it freeze. If it cycles and does not refill with water I would say that the water control valve is defective. Your refrigerator has 2 dual water control valves one is for the water filter assembly the one on the back is part number 61005626
Let me know what you find, Thanks sea Breeze click link below and enter model or part number in search feature.
http://servicepartstec.blogspot.com/
May 27, 2009 | Maytag MSD2756GES Side by Side...
Hi
If The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 29, 2009 | Estate TS22AFXKQ Side by Side Refrigerator
GE model GSH25JFTACC ice maker not working
Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jan 06, 2009 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
359 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
