Question about Intel Socket 775 Heat Sink and Fan up to Core 2 Duo E6600
My lap top is extra ordinary heated after some time.what is problem?
  • 741 Answers
You didn't mention if you had a laptop or a desktop. But on a laptop there is a small fan on the power supply that cools the CPU and all inside. The laptop must always be used on a flat surface like a table to ensure the air is circulating properly. Putting it on your lap or on your bed will cause it to heat more than usual. Yes they do get hot, the tempature is monitored by your BIOS and will automatically shut down if it gets too hot, this is to save the CPU from being damaged. As long as things are working properly then you are ok.
Posted on Dec 26, 2008
What is the definition of extraordinary
extraordinary - think of it as two words, extra meaning outside and ordinary meaning normal / everyday / standard. so extra ordinary is something outside the normal. Usually used to describe something 'more' or 'better' than ordinary
Mar 25, 2014 | League of Extraordinary Gentlemen: Black...
My processor is getting hot. What will be the solution.
Turn it off ... it will not get hot.
Typically, normal temperature is over 100 degrees. There have been reports of fires starting as the result of a overheated PC. I am not making the claim, I have not had this experience.
Heat is the enemy of delicate computer parts. They call them Lap Tops but you should never use one on your lap. Always place your lap top on a hard surface to insure the vents are not blocked and the internal fan can try to do its job. If you are concerned about the heat, you can get a 'cool pad' to use under your lap top. A cool pad has a fan which blows onto your lap top to keep it cool. The cool pad gets its power from a USB in your laptop. This cool pad should not be used for long periods of time on battery power for obvious reasons.
Thanks for your question at FixYa.com
Jan 30, 2011 | Computers & Internet
Battery maximum usertime&excessive heat generated while using. LENOVO G560 model Under warranty
Most newer lap top computers generate a lot of heat. The designers of the machine walk a narrow line between efficiency and customer satisfaction. The heat comes from the processor and the power supply of the screen. Designers incorporate a standard called heat pipe design into cooling the CPU along with a small fan sometimes. The heat pipe design is a static (no electricity used) means of wicking away the heat from the processor. When the temperature goes higher than the heat pipe can act, a small fan cuts in to reduce the temperature, but at a cost of using electricity from your batteries. The heat of the lap tops have caused people to seek medical help for excessive reddened legs, thus generating a medical syndrome called "Lap top Syndrome"
The batteries are LI-ion (Lithium Ion) construction and have to be re-charged with extreme care as excessive heat generated by charging can case the lithium to burn and cause a fire. Battery designers have placed a small smart chip in the battery pack to monitor the voltage levels and this chip will shut the battery down if too much heat is detected. Since the batteries are of Li-ion design, they start
Dec 29, 2010 | Lenovo G560 06793JU Notebook
Prob. 1unit shuts off by itself/ prob 2.back is cracking again
IT SOUNDS TO ME LIKE THAT YOUR UNIT IS OVER HEATING WHICH IS VERY COMMON WITH CHEAPER LAP TOPS. YOU CAN GO GET A LAP COOLER FROM STAPLES OR A LOCAL ELECTRONIC STORE THEY ARE NOT VERY MUCH. DID YOU DROP IT?
Nov 17, 2008 | Compaq Presario 700 470024-192 Notebook
Can't get picture back on lap top after connecting to ext monitor
Hello there. You sound very frustrated. try this, go into your BIOS settings and cycle the settings for your vga adapter, or even reseting the options to basic performance. also, you could hook up the external monitor and disable it while it's hooked up. that should fix any problems with that(if you still have an extra.)
Nov 11, 2008 | Nvidia Computers & Internet
Security torx screws
Go to a local hardware store, and ask them for a TORX screwdriver set.  The screws come in a large variety of sizes, and buying a set is the best way.  Make sure that at the base of the driver head it has a small hole for the security nib the screws have that prevents most ordinary screwdrivers from oppening them.
Jan 11, 2008 | Microsoft Xbox 360 Console
How do I use the stopwatch on iPod nano?
"iPod Software 1.0 for iPod nano introduces a Stopwatch feature. You can use the Stopwatch as you exercise to track your overall time and, if you're running on a track, your lap times too. The Stopwatch menu is located in the Extras menu. To access the Stopwatch from the main menu, select Extras, then Stopwatch, and then Timer (Extras > Stopwatch > Timer) to see its display. Total time of session Current lap time Left button (Start function shown)1 Battery indicator Right button (Clear function shown)1 The left and right buttons' names and functions will change, depending on the current state of the Stopwatch. Using the Stopwatch When you first enter the Stopwatch screen, the left button is labeled Start and the right button is labeled Clear. To use the Stopwatch, select the Start button (use the Click Wheel to highlight the Start button, then press the Center button). The Stopwatch creates a new session, and both the total time of the session and the current lap time begin counting: When these counters begin, the left button changes to Pause and the right button changes to Lap: If you select the Lap button, the current lap time will be recorded in the session's log, then the Stopwatch resets the lap time to zero and begins counting the new lap's time. The total time of the session will freeze for 5 seconds after you select the Lap button so you can quickly view your total time at the end of that lap. After 5 seconds, the total time of the session displays the correct total time and resumes counting. If you select the Pause button, both timers will stop counting and the left and right buttons will change to Resume and Done, respectively. If you select Resume, both timers will begin counting again. If you select Done, the Stopwatch records all the final times and creates statistics for your session in a log. Please note that selecting the Done button does not reset the display. You will see the final times for your total time and lap time displayed: To reset the display, select the Clear button (appears after you click Done and then select Timer again). Stopwatch Behaviors You can play music and use the Stopwatch at the same time. When iPod nano displays the Stopwatch screen, the Play/Pause, Next/Fast-forward, and Previous/Rewind buttons control music playback as usual. If you're playing music, you'll see an icon in the upper-left corner of the Stopwatch screen that indicates the current playback state: A play icon indicates that music is currently playing. A pause icon indicates that a song is currently paused. You can use the Menu button and the Click Wheel to navigate to other menus without interrupting the Stopwatch. Note: The Stopwatch will prevent your iPod from sleeping if it's counting. The Stopwatch will automatically stop if any of these three conditions are met: The total time counter reaches 24 hours iPod goes into hibernation (you can start it again when you wake iPod) You conne
Sep 28, 2005 | Apple iPod nano
Intel Socket 775 Heat Sink and Fan up to Core 2 Duo E6600 Logo
81 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
