Question about Fellowes Manufacturing Powershred SB-97CS Shredder
The bin is full light remains on even though it's empty. How to I get it to work correctly?
  • 2 more comments
  • speakersjohn Jan 13, 2009
    The bin is full; light remains on even though the bin is empty. Also the auto feed stopped working adn I have to rock the On/Off button to accpt papers.
  • Anonymous May 26, 2009
    I have the same problem with a fellowes sb-15c. I have ensured that the little sensors are free and clear, and they are clean. The "bin full" indicator light still comes on even if i turn the power off and on again and don't use the shredder. I have a feeling the sensors are not sensing correctly, but I don't know what they do, exactly. They are 2 LEDs, I think, maybe infrared LEDs, that are pointed toward each other. They are about 7 or 8 inches apart. Between them is a plastic piece mounted that kinda swings freely. I imagine that when the bin gets full the plastic piece is pushed up by the piling paper in between the 2 LEDs and cuts off the signal going between them. That's all I can figure out by just looking at it. Does anyone know how to fix it (cheaply)?
  • matthew624 May 26, 2009
    I have the same problem with a fellowes sb-15c. I have cleaned it out, made sure all paper is gone, made sure there is nothing on the little sensors on the bottom of the shredder. But a few seconds after I turn the shredder on, the "bin full" indicator is tripped, and the shredder will not operate. If I power it off and power it back on, I can get some paper through, but after that no more. The little sensors appear to be LEDs, maybe the infrared type. They are mounted about 7 or 8 inches apart, oriented so their tops point toward each other. There is a plastic flap that swings in between them. If the bin gets full, I imagine this flap is pushed up by the piling paper and blocks the signal going between the sensors. But there is nothing between these sensors, and it still tells me the bin is full. Does anyone know a workaround or a cheap fix?
    Oops, I didn't realize that first post went through :)
I called the toll free number for Fellowes Help Line, 800.955.0959, and spoke to John who was most familiar with the SB-15c. I indicated that the "bin full" LED was bad (actually the transmit bulb). After John ascertained that I had indeed cleaned the bulbs, he made available a replacement part, MasterCard or VISA required. Replacement of these bulbs is not for everyone. A level of technical ability and some tools will be required.
I have never had this level of technical support available on the first call. Kudos for Fellowes.
Posted on Jul 07, 2009
Does it still shred? I have the same issue but it seems like more than just a light problem because it stops completely. Does yours?
Posted on Apr 19, 2011
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
The water empty indicator keeps flashing indicating we need to empty it BUT it is empty !!!!Now the aircon won't work We emptied a lot of water however now it keeps beeping a warning,the compressor shuts...
I am NOT aquainted with the Maytag Portable AC..... But There has to been a sensor that tells the unit that the water bin is full...... If there is any moisture on the sensor and touching a ground probe then even though the bin is empty the sensor is still making a connection to ground. If you can trace out the wire that goes to the sensor you can unplug it from the board till it dries out or you replace it..... Only if you do make sure you empty the bin often or you will have water every where because the unit won't shut off if the water bin is full..... Hope this helps
Feb 05, 2011 | Maytag Portable Air Conditioner M6P09S2A
BIN FULL ON CONTROL PANEL IS ON EVEN THOUGH THE BIN IS EMPTY. PLEASE ADVISE
you need a bin full retrofit kit if it under warranty fellowes will install it if you need to buy the kit we have the kits cooksmobileshred@bellsouth.net 901-565-8188
Feb 08, 2010 | Fellowes C-320 Shredder
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
Indicator light remains lit even though it is a full cartridge
It seems there are "new" chips & "old" chips in these ink cartridges for the HP 1200 inkjet printer. I have a cartridge with a "new" chip in and it is working fine. The printer doesn't read the "old" chips. Something to watch for when using refilled ink cartridges.
Apr 17, 2009 | HP Office Equipment & Supplies
Flip HD Won't Return to Full 60-minutes-Recycle Bin Doesn't Work
Don't know if you ever found your solution, but check out this page - http://manitouheights.com/2009/09/03/flip-mino-ultra-camera-video-show-correct-time-remaining/.
I've also discovered that you shouldn't click on the little box to erase the videos after transferring them to your computer. That's what seems to screw up the timer.
Feb 28, 2009 | Pure Digital Flip Video Ultra Camcorder
Fellowes S8-*5c
If this is actually an SB-15C I posted a solution elsewhere and will repeat it:
Feb 13, 2009 | Fellowes Powershred SB-85C Shredder
Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
Fellowes Manufacturing Powershred SB-97CS Shredder Logo
730 people viewed this question
Top Fellowes Manufacturing Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
 Bob Buchholz
Bob Buchholz
Are you a Fellowes Manufacturing Office Equipment and Supply Expert? Answer questions, earn points and help others
