Question about RCA F32649 32" TV
RCA PROBLEMS We have had our rca for about 5 years. After the tv is on for a few minutes I hear a loud sparking sound and the picture goes off and comes right back on and it just repeats this cycle. Can anyone help me with some ideas on how to fix this problem?
  • 1 more comment
  • Paul Hadidon Apr 15, 2007
    Thanks for your help. This fixed the problem for about 12 hours and has burned a hole through the epoxy. Any Ideas how I can get past this?
    This fixed the problem for about 12 hours and the hole is back through the epoxy. Any ideas how I can get past this?
  • Anonymous Dec 01, 2007
    SPARKING SOUND FROM THE BACHSIDE OF THE TV SAMSUNG
    Problem Solver:
  • 11 Answers
Two common problems with RCA TV's. It sounds like your flyback is going on you. There is probably a hole and it is arcing off a cap/ or something. You can order a new one or you can try and find where it is arcing by taking the back and looking at it in the dark to see where the arc is coming from. If you can find it try using a plastic epoxy to fill the hole
Posted on Apr 14, 2007
  • Jim Carr Nov 14, 2007
    Sorry, just checking back now on this. It was a shot with the epoxy. Some of the smaller TV's this works like a charm, but I guess there is too much juice coming out of it and it cant hack it. The only solution is a new flyback. Sorry about that
RCA DLP tv, the picture goes blank after a few minutes, and then comes back on and goes back off again...
Take it back to the store. If warrenty is expired then you will have to get a new TV or send it for repair . I don't know of anyone that comes to your home for TV repair. Sounds like picture tube is out of it.
Aug 17, 2013 | RCA Televison & Video
Rca hdtv 52inch will play fine then picture goes black but still has sound.. after a few mins.picture will come back on , and will play fine could last all day or may go out again in a few mins.
My tv is relatively new, but the bad thing is that I had an old; big screen tube type rca model; home theatre, that was heavier than a car, and it went out, due to the cracking and popping sound, off sometimes, and back on.
What is strange is the new tv now, the hdtv, light weight, about five years old, is doing the same thing. Actually, now, the power will not even come on. The lcd green light in the front goes on and off.
Take no offense, but I thought I would not have these problems anymore. What do you suggest?
Feb 16, 2010 | RCA HD52W59 HDTV Projection Television
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
My rca tv picture goes off after a few minutes but the sound stays on then the picture will pop back on then it goes through the same deal again
Resolder all pinns on FBT flyback transfomer and ck capacitors cp150 2200uf 16v if it is swollen or puffed up on top it is bad replace it and 2 more cp114 cp 120 220uf 35v.
Sep 18, 2009 | RCA R52WM24 52" HDTV Projection Television
Rca truflat tv goes blank after 30 minutes, then I can't get a
When this goes off is there a loud crack? If so perhaps the B+ supply is increasing increasing the the EHT to the CRT and the crack is the voltage across the spark gap in the crt base jumping to chassis/earth shutting down the TV. Or perhaps just a dusty/dirty eht cap, again EHT discharge, or could be a eht tripler being faulty. Further investigation with the aid of a service manual is required I am afraid.
Sep 12, 2009 | RCA 32F531T 32" TV
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
Loud Buzzing Sound
Sounds like the cooling fan blades are hitting something (possible worn bearings).
Apr 21, 2008 | RCA P52926 52" Rear Projection Television
Sometimes no picture on RCA tv
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Oct 28, 2007 | Quasar SP-3233 TV
RCA HD52W59, Serial: G075CN0AO, Chassis # 1TC222A
ask your service depot about the service flash on the covergence connector,causes intermittant faults and deflection problems /
Aug 22, 2007 | RCA HD52W59 HDTV Projection Television
RCA F32649 32" TV Logo
67 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
