Question about SanDisk Sansa e250 MP3 Player
My sansa player has hung and does not reset
I had connected my sansa player to the comp. I disconnected it. Later on when i tried connecting it..it was not detecting it. Hence disconnected it and my menu just hung.Even on pressing the power off button it does not reset. Please help!!!
Press the power off button, do not release, (20sec) wait until the screen blank. I suspect firmware bug, try to play around with increase timing on AutoShut-Off, example 10 mins, at the Setting.
Posted on Apr 26, 2007
My Sansa 2 gig MP3 player is "stuck" on check mark English and will not advance to any other programing instructions
Please try to reset your sansa as the ipod has hung up due to an error in the files. Find a small hole on the sansa, use a small pin to reset, the set should come alive. Connect your sansa to the PC, select and save all the files to a folder . then delete and format your sansa.thereafter load back the files after a virus scan and making sure are good uncorrupt files. This must solve the issue. Good day
Jul 07, 2010 | SanDisk Sansa m250 MP3 Player
Just says connected until the battery dies.
first off if you can turn the player off
try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
if that doesnt fix your problem try this...
if you can actually connect your sansa to the comp. and see it in explorer try this....
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will probably work again
I hope my post was helpful let me know!!!!
Mar 14, 2009 | SanDisk Sansa e250 MP3 Player
NOT DETECTING
first try changing the usb mode in your settings if still doesnt connect try this...
Mar 13, 2009 | SanDisk Sansa e270 MP3 Player
I cant connect my sansa player fuse with my pc it only charges my player but it dont connect to pc
try this...
Mar 13, 2009 | SanDisk Sansa Fuze MP3 Player
It keeps saying that its refresing database and is not loading
first try this...
Mar 13, 2009 | SanDisk Sansa e250 MP3 Player
Cannot format
try this...
Mar 11, 2009 | SanDisk Sansa e200 MP3 Player
My Sansa e270 Will Turn On Then When It Starts Loading It Will Get 3/4 Of The Way Then It Goes To A Black Screen.What Do I Do?
try this...
Mar 01, 2009 | SanDisk Sansa e270 MP3 Player
Computer won't read mp3 player
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Sep 05, 2008 | Audio Players & Recorders
Can't disconnect
instead of dragging and dropping, try moving or copying the files to your player.
other wise i would say just to turn off your comp or player.
hope this helps!
~Rebecca~
Jan 13, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa not connecting to computer
try going to recovery mode and upgarade the firmware of the player. Recovery mode = enable hold switch press the record button and press the menu button until it shows welcome to recovery mode on the player.
Jul 26, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
62 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
