Question about Motorola Mobility V500 Cellular Phone
Keys not always working
I quite often have to press certain keys more than once before they register, especially the number 1 key
  • 201 Answers
Hi, usualy your problem is caused by currotion caused by liquid damage, water, sweat etc. Your need to open the phone and clean the keypad membrane this will solve your ploblem
Posted on Dec 24, 2008
How to reset administrator code i have lose
Procedure 1) Press the Utility key 2) Press the following keys in this order. Stop-> 0-> 0-> Stop-> 0-> 1 3) The Service mode screen will appear. 4) Press [ Admin. Registration] 5) Using the 10-Key pad, type the 6-digit administrator number (000000 to 999999) to be register or changed. 6) Press the [Yes] key to register the administrator number.
Oct 04, 2014 | Konica Minolta bizhub Office Equipment &...
How to reset date on royal cash register model alpha 710ml
Page 7
To set the date
1 At the prompt, use the rounded Number keys to enter the last 2 digits of
the year. For example, for 2006, press 06. Press the Amount Tend Total
<Enter> key.
2 Use the rounded Number keys to enter the 2 digits of the month. For
example, for February, press 02. Press the Amount Tend Total <Enter>
3 Use the rounded Number keys to enter the 2 digits of the day. For
example, 24. Press the Amount Tend Total <Enter> key.
4 Use the rounded Number keys to enter the 2 digit hour. For example,
09. Use military, or 24 hour, time for hours after 12 noon. For example,
if you want to enter 8pm, press 20. Press the Amount Tend Total
<Enter> key.
5 Use the rounded Number keys to enter the 2 digits of the minutes. For
example, 54. Press the Amount Tend Total <Enter> key.
Using the information in this example, the date and time are set to
02-24-06 8:54pm.
Sep 17, 2014 | Royal alpha 710ml thermal cash register,...
How do you program a certain item to a certain key?
Program PLU with FIXED Price.
1. Enter Program Mode
2. Press [qty/time]
3. Type the PLU # 1-999
4. Press [PLU] key
5. Type the PLU Price using the number keys
6. Press the Department key for the department you want it linked to
7. Repeat as many times as you want
8. Press [qty/time] key
Jun 07, 2014 | Royal Cash Register 500dx
Keyboard incorrectly types a mixture of letters and numbers when certain keys are used.
There are a couple of things you could try:
1. Remove the keyboard following a service manual for your laptop, and reseat the ribbon cable underneath it.
2. If the problem still isn't solved, the keyboard should be replaced
Feb 03, 2013 | Computers & Internet
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
How do i register my phone number into a used ux-p200
1 Press FUNCTION key once and DOWN ARROW twice.
2 Press RIGHT ARROW once.
3 Press RIGHT ARROW once.
4 Enter your fax number by pressing the number keys (max. 20 digits).
• To insert a space between digits, press #.
• To clear a mistake, press speaker .
5 Press START/MEMORY to enter the fax number in memory.
6 Enter your name by pressing number keys for each letter as shown in
the chart below. Up to 24 characters can be entered.
Jan 08, 2012 | Sharp UX P200 Plain Paper Thermal transfer...
When I press certain keys like P I get 6
This is yoru number lock function
look along the "F" key row for the NumLk or picture of the number 1 in a square. then hold down the Fn key on the lower left of the board. press the "F" key that corresponds to it and this will disable it.
Feb 18, 2010 | Acer NSK8458AN Keyboard
After many years have misplaced the instruction manual for our Vista 200. Need to know how to set up names and numbers for the automatic dialling feature.
First, ensure the display is bright enough. If it is not, press successively on the "Brightness key" that is located on the top of the phone above the "Memory key". You have 8 brightness settings. Note that the "Brightness key" has no label.
You are now ready to start programming.
1. Press the "Memory key". It is labelled "Memory" and is located above the "Memory keys" numbered 1 to 10 on the right-hand side of the phone.
2. Press the "Memory key" you want to program. (1 to 10)
3. Enter the number you want to program using the "Dialling keys"
1, 2, 3,
4, 5, 6,
7, 8, 9,
*, 0, #
4. Once the phone number is entered, press the "Memory key" again.
5. Now enter the "Name" for the phone number you just entered. To do this, you press the "Dialling keys" as follows:
For A press the "2" key once,
For B press the "2" key 2 times,
For C press the "2" key 2 times,
For Q press the "7" key 2 times,
For Z press the "9" key 4 times.
Use the same for all letters.
To go to the next letter, press the "Right arrow key".
For a space, press the "Right arrow key".
6. Once the name is entered, press the "Memory key" one last time. You are done.
7. To test it, press the "Memory key" you just programmed.
Oct 19, 2009 | Bell BE-412CID Corded Phone
Cant put code in DC279/62F radio from 51 reg clio
You need to press the certain keys as often as the number says. Example Code 7711...... you press Key 1 for 7 times, key 2 also 7 times and key 3 = 4 just once.
Aug 17, 2009 | Philips Car Audio & Video
Try this, for example june 30 2004 =
Put the mode key in PRG position In round number keys press 063002 then press #/ST/NS key
If that works to set the time in round number keys press 1100 then press Qty/Date or 1305 for one 05 pm. I have a 587 cx and can't fiqure out how to print my reports X Z
Aug 21, 2008 | Office Equipment & Supplies
Motorola Mobility V500 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
