Question about Apple MacBook Pro Notebook
My screen has gone black on my macbook
I was youtubing and all of the sudden half of the screen went black.. I powered down and waited a few seconds and turned back on and I get the grey apple and the loading indicator but immediately following that, it goes black again.. Its on and I can hear the drive but nothings on the screen.. What do I do? My mac care is up so they wont help me :-(
  • Apple Master
  • 4,338 Answers
  1. Disconnect any devices connected to the computer including printers, hubs, and third-party keyboards or mice, and test the computer again by trying to turn it on.
  2. Press the control key, the command key, and the power button simultaneously and hold for three seconds to try to restart the computer.
If that does not work :
Reset the PRAM and NVRAM
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 25, 2008
  • Marian Clarke Jul 06, 2013
    Brilliant - thank you!
  • 846 Answers
Sounds like your backlight is defective. When the bulbs go out, they will only run for a few seconds and then overload the inverter, causing it to turn off. If you're out of warranty, somebody has to open the Macbook screen and replace the backlight. The part is available on ebay. Here's aguide on how to disassemble a Macbook. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Macbook Repair Services.
Posted on Jul 26, 2010
  • 3 Answers
There is also a possibility that the discrete graphic card is faulty.
This happened to my MacBookPro Retina 15".
Upon a restart or power up, the screen goes black. The keyboard backlit and rest appears to be responsive still.
If I press the power button again and put the unit to sleep, wait approx 1 minute, then press the power button again, the screen comes back on. This time, the integrated graphics card is utilized.
If you do not wait long enough after putting the unit into sleep mode and wake it up, the screen shall remain black.
Once the screen is functioning, you can continue to use your laptop as long as you put it into sleep when not in use. If the laptop restarts or powers down, you will get a black screen.
To verify if your laptop is experiencing a similar issue, upon login, If you check 'About This Mac' under the Apple logo menu, you would notice that the Graphics is utilising the built-in Integrated Intel Graphics board and not the discrete GPU. The discrete graphics card is no where to be found under the 'System Report' -> 'Graphics/Displays' section.
To address the issue thoroughly, most likely the logic board will need to be replaced (as advised by Apple Genius) and this can be a very costly exercise. For me, I have no real need for the higher performance discrete GPU, so I am happy with the workaround, until I get my next laptop...hopefully Apple shall release a MacBookAir with Retina screen very soon. :)
Posted on Nov 05, 2014
Why macbook not turn off blank screen
If the Apple laptop (or desktop) doesn't shut down properly, try pressing and holding in the power button for 3-5 seconds. This will force a shut down. Good idea to wait a few minutes before attempting a restart again.
Aug 30, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I can turn it on, and if i dial a numbre i can make a call, and if someone calls or texts me my phone will ring, but the screen is black, and i really need to fix it. Its started out with half of the...
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 10, 2012 | Nokia 7610 Supernova Cell Phone
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
Have a macbook pro and it has locked up, black screen now and isn't responding to mouse or keyboard
This has also happened to my Macbook Pro - nothing would work, so i basically pressed the power button until it closed down and waited a few minutes and turned it back on. The problem ( touch wood) did not come back again yet. Good luck!
May 18, 2011 | Apple MacBook Pro Notebook
Acer aspire one D255 went away from notbook for half an hour or so, when i got back the screen was black. It won't come back on. Help
Hi, try disconnecting the power completely and take the battery out, wait a minute and put the battery back, connect the power and turn the machine on, if still no luck try holding the power switch for over 3 seconds, wait few seconds then try turning on... if still no luck then there might be aproblem with the machine that require taking it to service center... best of luck
Jan 30, 2011 | Acer Aspire One D255-2670
Hello, I'v got a MacBook Air, and it won't turn on as it goes: on, the Apple logo shows, the waiting wheel spins and then turns off again, and keep doing this till i shut it down for good... it won't turn...
Try:
1. Turn your MacBook Air off by holding down the power button for about 10 seconds.
2. Hold down one of the Shift keys and press the power button for a few seconds. Keep holding the shift key for about 1/2 minute. This will start the machine in "Safe Mode." It will check to make sure there are no errors on your hard drive and do other tasks to hopefully fix your problem.
3. Once you see your Desktop (if you do), click the Apple menu and click "Shutdown".
4. Start the computer normally by holding down the power button for a couple seconds.
If this doesn't work, you may need to reinstall the operating system. On a MacBook Air, that's a bit more complicated. You'll need either the external DVD drive (an optional purchase for the Air) or another computer. Your computer manual explains how to install software on that other computer (may or may not be necessary) so that you can use that computer's DVD drive to put the disc in and reinstall Mac OS X operating system.
Good luck! Please let us know if you have further questions or problems.
* If you find this information helpful, please rate my solutions and recommend me. Thanks! *
Apr 21, 2010 | Apple MacBook Air
Macbook screen went black and now there's nothing
Reset the SMC and PRAM.follow the process in Apple.com. Hope this can solve the issue
Jan 24, 2010 | Apple MacBook Pro Notebook
Hi I have a samsung syncMaster 920N The screen has suddenly gone blank - the power light is showing. I have a second identical monitor and have swapped cables but no difference Is it a repairable fault?...
This happened to me a few months back. I removed all cables and left it for 2 days. Switched back on on it worked fine. That is until yesterday when half the screen went black. I found that my driver was out of date. I have undated the driver but have decided to leave it off and unplugged for another day.
You could try this. You say you have another monitor, i would suggest using it for a few days and the try the old one again.
Dec 05, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
A Frozen 2008 Macbook Air
try You can force a frozen MacBook Air — or any current Mac laptop — to shut down and restart without removing its battery. You just hold down the power button for a few seconds until the machine shuts off, then wait a few seconds, then turn it on again.
Mar 08, 2009 | Apple 13.3 MacBook Air 1.8GHz 2GB RAM 80GB...
Mac Laptop has black screen
Try starting in safe mode, this usually bypasses the graphics drivers, which could be in a funky state:
To start up in safe mode
Shut down your computer and wait 10 seconds.
Press the power button.
Immediately after you hear the startup tone, hold down the Shift key.
You should press the Shift key as soon as possible after your hear the startup tone, but not before.
Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
Jul 31, 2008 | Apple MacBook Pro Notebook
Apple MacBook Pro Notebook Logo
7,650 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
