Question about Jenn-Air JCD2295HES Side by Side Refrigerator
I need help getting the cover off the start relay and overload parts of my JennAir refrigerator's compressor. I'm told it just pulls off, but it doesn't budge with strong finger pulling, and I'm not sure if it's safe to pry it off. The plastic is pretty brittle and I don't want to break it. Help??!!
  • rberley836 May 18, 2009
    The defrost timer is under lots of plastic at the top of the fridge .. how do I take the cover out to get to the timer? Looks like everythhing is interconnected and needs to be unscrewed.
    Thanks!
  • 700 Answers
Look real close around the sides of the cover and you will see two places in the middle wher the screw drivee can be slid in to disengage the clipa and then just pull off. Be sure to lill the power firsat though thaanks for using Fixya and have a Merry Christmas.
Posted on Dec 24, 2008
My fridge is not cooling nor is the freezer. i checked the compressor for continuity no beeps.when i plug it in to to start the compressor it tries to start then i here a click on th
Hello Philip;
My name is Peter. I am a retired field service refrigeration technician.
The clicking sound is the overload relay trying to start the compressor. A overload relay is like the starter on our car.
Go into the following website and put in your model number. You will get diagrams and part numbers.
Record the part numbers of the overlay and condenser. You do not need to replace the cover on the side of the compressor.
You can either pay a arm and a leg to purchase these parts from your local store or purchase them for about 50% less over the internet. I have purchase and installed used parts.
Before you go ahead and purchase these parts:
a.) Remove the lower front toe plate. Either it is held on with 2 screws or pop off - pull out clips.
b.) Check to make sure the leveling jacks are not down and the wheels are on the floor to pull the unit out from the wall.
c.) Pull out far enough where you can get behind it.
d.) Unplug the refrigerator.
e.) Remove the lower back cover.
f.) Pop off the cover on the side of the compressor.
g.) Note the over load relay components mounting for replacement.
h.) Remove the components.
I.) Shake the white component. If it rattles, it is bad.
j.) Inspect the 3 metal stems on the compressor. If they are burned or melted, then you have a bad compressor. ($650.00-$800.00 repair).
Water Filters Lawn Garden Appliance Parts
Mar 02, 2016 | Magic Chef Refrigerator. 10.0 cu. ft....
HELP! - My fridge freezer is not cooling - clicking sound heard but motor not coming on
Hello Michelle;
Lets fix this together. The clicking sound that you hear is referred to as a overload relay. The overload relay is an electrical component that starts and stops you compressor. It is very common for the overload relay to fail over time.
First, locate and purchase a overload relay. If you have a Trible's
in your area that's great, if not Lander's, Sear's, .... If you can wait a few days you can get the part over the internet for half price or less.
I do not have your model number otherwise I would give you the part number.
Having the part, pull the refrigerator out where you can move freely behind it. Unplug the refrigerator. There is a bottom cover that you need to remove. This cover is fastened either with Philips or hex head screws. Remove the cover. Open the new overload relay parts and lay them before you. Study and observe them.
There is a black box on the side of the compressor which holds the overload relay. The box is held on with either metal or wire clips. Using a flat head screw driver pop the clips off. Compare the parts on the compressor with what you have. Note the location of the connecting components on the 3 compressor pins, and the first piece to put on the compressor is the white piece with the 'V'. Using your flat head screw driver, wedge the components off the compressor (Remember how they go back on). Do not pull on the wires - just the connector ends. Replace the components. Shake the white piece - if it rattles or is burned it is bad. If you can not get the black box cover back on - not necessary, it's a dust shield.
Note: If you have a LG, bottom freezer 599, do not bother. Both the overload relay & compressor need to be replaced. Buy new, not LG.
Oct 28, 2014 | Refrigerators
Asd2522wrb04 amana side by side refrigerator. clicks like it is coming on. then goes off. nothing freezes or cold. Why?
I believe what is happening here is a defective start relay and overload. Right now I would pull refrigerator away from the wall and unplug. Next remove the cover over the compressor feel top of the compressor and if it is not possible to keep your hand there from heat tells me the compressor is trying to start. Keep unplugged until replacing the Start Relay Kit below.Most times the compressor that begins to do these symptoms can be fixed by replacing the=>
W10189190 Relay and Overload Kit
These parts can be found by removing the rear cover near floor and then pulling the cover on the side of the compressor. Click Here=> ASD2522WRB02 Unit Parts In that photo is a compressor top left of photo. Number location 13 is the cover of the part I am talking about and location 12 in that photo is the start relay and overload. If you have trouble I will be here to assist you, Thanks Sea Breeze
Sep 26, 2011 | Amana Refrigerators
Our amana refrigerator is making a noise, a hum and then a "click". The freezer is no longer working and the fridge part is no longer cold. It's a 2004 and we don't know whether to get...
It sounds like you are hearing the overload on the compressor closing. When the overload closes the relay tries to start the compressor (that might be the buzzing sound) and if the compressor doesn't start the overload opens and turns the compressor off. You will need to replace the relay on the compressor.
Jul 31, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
MZD2766GES No cooling.Stat(slide) set to call.120v to unit.Lights on.No compressor operations.Manually defrost last few months.
Lets check start relay, run capacitor and thermostat. Also need you to pull away from the wall and unplug, remove cover over compressor and then feel the top of the compressor to see if warm or too hot to keep hand there. Should you need a start relay you will need=> 12002784 Relay and Overload Kit
12002784 Relay and Overload Point and Click Parts If the compressor is cool I want you to check the Adaptive Defrost control=> 12002104 Adaptive Defrost Control Sometimes these parts act like the compressor start relay and stop compressor and fans and even sometimes one or the other. The thermostat should also be checked while unplugged with an OHM meter=> 61005327 Temperature Control Here is a pdf with the locations and should you have any questions I will be here again later, Thanks Sea Breeze
Here=> MZD2766GES
Apr 16, 2011 | Maytag MZD2766GES Side by Side...
The refrigerator doesn't cool . The fan comes on in freezer, there is a clicking noise that comes from the back.
Unplug pull away from the wall and remove the cover that covers the compressor. While unplugged feel top of the compressor. If too hot to keep hand there I would believe you may need to replace the start relay=> OVERLOAD/RELAY W/CAPACITOR
Please do not leave plugged into power as the compressor is trying to start and getting very hot. Too much of this will cause the internal overload to remain open. and early compressor failure.
. 67005560-2 Start Relay With Capacitor And while inside please insure the fan runs when plugged in at compressor. Here is your location=> Part 4 in photo is the part below=> MZD2665HEW Compressor Components
Have more questions please ask and please rate this solution, Thanks, Sea Breeze
Apr 11, 2011 | Maytag MZD2665HE Side by Side Refrigerator
My Kenmore 106.56573300 is not getting cold and is clicking.
sounds to me based on your description that you possibly have a bad relay on compressor. it is possible the compressor has failed due to a bad start relay and what you are hearing is the overload kicking out when trying to start.. you will have to remove the back cover from refrigerator and gain access once you gain access remove bottom cover and you will see compressor... you can get parts from several online appliance places... kenmore i would probley go to
www.sears.com then hit the parts direct link on the top of page
enter your model number and a parts diagram will appear go to compressor picture and pick the relay /start and overload give that a shot if it still clicks the compressor has failed and will need to be replaced // good luck to you
Jan 22, 2011 | Kenmore 53642 / 53644 Side by Side...
HOW DO YOU REPLACE A START RELAY SWITCH ON A FRIGIDAIRE SIDE BY SIDE MODLE FRU26SA
Power off i.e unplugged
Open the back
Remove retaining clip on wiring side of compressor plastic cover.
NOTE wiring connections to terminals on the OLD relay. 1, 2 4 4 ect... make a simple wite color to terminal number sketch.
PULL off PTC relay WITH terminals by pulling HORIZONTALLY (Usually to the left / 9 O'clock position)
NOTE the thermal overload comes off WITH the PTC relay.
Remove wire from Thermal overload terminal and transfer the thermal overload to the new PTC relay.
Slide NEW PTC relay onto compressor terminals
Transfer remaining wires from OLD PTC to the correct terminal on the new PTC relay.
TEST compressor start before installing cover... PLUG in unit
After the test unplug the unit... reinstall the plastic cover and wire clip.
Reinstall back panel
Return unit to service.
Thanks for choosing FixYa
Kelly
NOTE the thermal overload will s akl
Sep 19, 2010 | Frigidaire Side by Side 26.0 Cubic Foot...
Whrilpool refrigerator model ed25te will not cool or freeze. lights are on, fan works
Your compressor may be trying to start and have a bad start capacitor, start relay or overload. If you hear the fans that tells me the thermostat has also told the compressor to start. Unplug and pull away from the wall. remove lower cover over the compressor area and feel the compressor on the top. If too hot to keep you hand there leave the refrigerator unplugged until we locate why the compressor is trying to start but will not. tell me the age of your refrigerator. I will keep checking for a response from you and will be here to help, Thanks, Sea Breeze
Jan 16, 2010 | Whirlpool ED2SHGSM Side by Side...
JennAir SxS JCD2289AES follow up Unit stopped cooling in September. Evaporator iced up. Replaced Adaptive Control Board. Problem solved-for one night only. Next morning only lights work. Have studied...
If the unit was freezing up, then the start relay and overload did not need to be replaced.
Chances are, the defrost heater(s) are burned out on the evaporator. Confirm your Make and Model number to me and I will get more info to you.
Dec 28, 2008 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
102 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
