Lamp hour reset
We recently replaced the lamp for our Panasonic PT-AE700U
We forgot to reset the timer through the on screen menu as instructed.
Now, after 3 weeks of use, the projector refuses to boot up.
We suspect the projector didn't know we have replaced the lamp.
Now, is there a way to re-set the lamp hours without going through the on-screen manu --- as the projector no longer boot up, on-screen menu is not accesible.
  • 1 more comment
  • Anonymous Jan 22, 2009
    i have the same problem but the "solution" posted doesn't make sense.
  • Anonymous Feb 02, 2009
    how do you reset the lamp time hours?
  • Anonymous Mar 01, 2009
    I have an 3M MP7750 projector, on witch I have just changed the lamp. AfterI did this, it worked fine for a while.. then it suddently wouldn't turn on. When I push the power, it just begin to start, but then 3 "high" pitching sounds starts.. befor the fan works really much and it turns itselfs off (like a safemode?). Can anyone help me??
    Odd Levi
  • 107 Answers
I don't thing that because you were not reset the time lamp used now your LCD projector stop function
What was exact the unit did? no power at all or some LED light up or flashing. In any case to reset the lamp time use you must enter when unit is on
As you mentioned you did replaced the new lamp, You should check again if you reinstalled properly the lamp and lamp cover because under the lamp cover it had a safety switch if this SW not active then the unit will be in protection mode
I sugges you to remove again the lamp and reinsert properly and secure the lamp cover and try it again and if it still is not go then let me know what are the status of the 2 LED
Posted on Jan 15, 2009
Posted on Dec 15, 2009
My projector goes blank every one minute
This is most likely the lamp. Replace the lamp and then in the setup menu you need to reset the lamp hours to zero. If you have replaced the lamp then you need to still reset the lamp hours to zero. If you do not it will never stay on longer than that hour. If both of these have been done and it is still doing this then it is over heating and this could be caused by lack of air flow (clean filters) or a bad power board.
Dec 01, 2014 | Panasonic Pt-ae700u High-definition Home...
Reset lamp for Panasonic PT-vx400
There should be a menu that goes across the top listing video, audio, setup, projection....etc. Either under setup or advanced there will be a drop down menu with lamp settings under it. Under that menu will be a reset lamp or something as direct as lamp hours. That is where you can reset the lamp timer.
Feb 05, 2013 | Panasonic PT-VX400 Projector PT-VX400
Can't reset lamp timer after lamp replacement on Panasonic PT-AE40000
I have a Panasonic PT-AE4000U and could not reset the timer after replacing the bulb with a, non-Panasonic branded bulb. Calls to tech support were not very helpful. It was another bad customer service experience. Through troubleshooting it myself, I discovered the solution was simply to unplug EVERYTHING (serial cable, hdmi cables, etc.) from the device, power it off and back on. Follow the procedure in the manual, the timer immediately reset!!
Feb 11, 2012 | Panasonic Office Equipment & Supplies
How to reset lamp hour of panasonic pt lam1 lamp
Do the following for reset the lamp hour timer of Panasonic PT-LM1U
1. Power ON the projector. (wait for the display)
2.Press the menu button to display main menu and then press the up arrow or down arrow to select OPTION2.
3. Press the Enter button t display the OPTION 2 menu.And press the up/down arrow to select LAMP RUNTIME.
4. Press and hold Enter button for approximately 3 minutes.
5. The LAMP RUNTIME will change to TIME RESET. (power off).
6. Turn off the power.
Jul 18, 2011 | Panasonic ET-LAM1 Projector Lamp for...
How reset panasonic ptae700u when you change lamp thank you
Go into the menu under "Option" and reset lamp hours to zero
Aug 03, 2010 | Panasonic PT-AE700U Multimedia Projector
How do I reset my lamp timer on a panasonic HDTV
go into menu.... and you will find lamp setting. reset it to zero hours
Nov 17, 2009 | Panasonic PT-50LC14 50" Rear Projection...
PT-AE700U Lamp led flashes red
Reset the lamp hours. Here is the manual on how to reset lamp time.
Good Luck and Please Rate Fixya!
Feb 28, 2009 | Panasonic PT-AE700U Multimedia Projector
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
SPLIT for Models:
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
3,661 people viewed this question
