This seems to be a popular problem. First I would unplug the fridge and plug it back in, sometimes it will reset the control and the solonoid for the water fill will stop.v if it does not stop that may be the water fill timer contacts are fused shut which means you need a new control board. I would also check the water basin for a float or water sensing probe. If they are dirty or damaged then it will not sense the water level and keep filling. I would also check the water fill valve to make sure it is not stuck open. If it is the board it might be easier to shut the water off and buy ice, they can be pricey. Good luck
SOURCE: Water leak from freezer
Two possibilities. Water leaking fro ice maker or the drain is blocked behind the back panel inside freezer. I will send links soon on how to fix it. Sea Breeze
