Question about iRiver H10 MP3 Player
The machine doesn't let me record audio
After a few times of recording audio (like microphone), the remaining record time got to 0. Even after emptying the H10, its still on 0 record time. What to do?
  • 8,596 Answers
Make sure hold not engaged
reformat the player
Posted on Jun 26, 2008
WHY WONT IT RECORD OR REPLAY - THE MACHINE RECORDS TIME BUT THERE IS NO SOUND
try plugging in an external microphone, if that works and it records then the microphone element in your machine is bad or a wire has broken off of the microphone
Apr 13, 2015 | Philips Pocket Memo LFH9370 Handheld...
Tip
How to record audio on Mac OS X El Capitan
Some users of Mac OSX 10.11 probably find that recording audio is not so easy as before. Since this operating system made some changes in "Sound" preference, lots of audio recorders become malfunctional. This issue can be solved by QuickTime if you just need to record mic voice, but recording audio from sound card is another story. Soundflower is still helpful, however you may be troubled by the complicated settings. To make this stuff simpler, share you an efficient solution here.
Step 1: Open the online audio recorder, click Start Recording to activate the application.
Step 2: Follow the instruction and install a launcher, the recorder will open. You will only be asked to install the launcher when you use the app for the first time.
Step 3: Select the Audio source at the bottom of interface, it allows to record sound played on Mac, voice from microphone or both.
Step 4: You can start to record sound on El Capitan now, the sound can be streaming music, radio, voice calls or others. Click the Record button, recording will be started.
Step 5: When you want to stop, click the Record button again.
Step 6: You can access to more functions like play, rename, edit ID3 on Library interface.
Based on my experience, the application doesn't have restriction on recording time. The audio will be saved as M4A which can be played with QuickTime and iTunes.
on Apr 27, 2016 | Apple Mac OS X
Sound capturing problem
Webcam doesn't record sound,try a microphone,and make sure that sound recording software is running when you record sound
Aug 27, 2012 | Gateway Computers & Internet
The best Rec. levels
As with all recording levels it's best to keep them to a max of 0 VU on the level meter. Some say an odd peak into the red or above 0 VU is acceptable, but it should not go to high. Sett it on the loudest part of what you are going to record, then the rest of the time should be OK. Try some loud music first if it's all speech. That should set the right level for the speech. It is possible to increase the audio level on Audacity afterwards anyway.
Oct 01, 2017 | Samson C03U Professional Microphone
Cant hear audio on tascam 2488i brand new to using it but i do understand how to record a track on my display screen i can see the audio i recorded but no sound what so ever i have my headphones plugged up...
hi
Tascam Digital recording is an effective solution for broadcast-quality home recordings. The Tascam 2488 is a user-friendly tool and useful for home recording situations, especially when writing songs or cutting demos. It even has bus compression and processing for your final mix to give it that "mastered" feel. There are other recorders as well.
Instructions
  1. Learn your gear. The Tascam 2488 DAW offers 24 discrete channels that can be recorded at up to 24-bit resolution. 16 tracks can be recorded simultaneously, via eight XLR balanced inputs and eith 1/4-inch unbalanced inputs. There are several high-quality built-in effects, such as reverb, delay, modulation, compression and a great tool for guitarists: amp and effect modeling. So you can simply plug directly into the console and get live amp tones.
  2. Record or program the rhythm tracks. Most Tascam products offer a large library of built-in drum loops to construct rhythm tracks, so you don't even need live drums just to get a song down. You can designate the tempo of your song from the transport located on the right side of the console; this is where you would use a variety of buttons to make edits, undo or redo and automate punch-ins
  3. Record your base rhythm instrument. Let's say a rhythm guitar. There is a dedicated guitar input located on the front of the console, and once you're plugged in you can use the aforementioned amp modeling features to dial up a sound.
  4. Record the remaining track or tracks. This could include bass, vocals, keyboards, horns or any other instrument. The process is always the same. Arm the track you wish to record on, hold in record and hit play, and the machine begins to record whatever you are playing. When you're done, hit stop. If you want to undo what you recorded, simply hit the undo button.
  5. Repeat these steps on any other instrument you want to record. Plug a microphone into one of the first eight XLR inputs, the first 4 of which have phantom power for studio condenser microphones, arm a track and record.
  • If you need to punch-in a section, you can automate it by dialing up the time in the song you wish to replace using the auto punch function. When you enable this and choose the time in the song you wish to record over, once you hit record and play it'll start the track a few seconds before where it begins the punch-in and it will only go into record when it reaches the designated time stamp.
Do not rush. Proper recording takes time and patience.
hopefully this can help
regards
Jun 11, 2011 | Tascam 2488 Portastudio Multitrack...
Friends say When i speak sounds like Static any 1 know how to change setting or find it in computer. Im using Satellite Fusion
The external microphone itself could be the culprit, or its connection to the 3.5mm port could be flaky. To test the theory do this:
1 Connect an external microphone to the computer.
2 Click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder.
3 Click the Record button and speak normally into the microphone.
>>>> WIGGLE THE CONNECTION AT THE LAPTOP OR FLEX THE MIC CABLE WHILE RECORDING. Maybe even narrate what you are doing while you record your voice. "Flexing cable near mic, now near plug..." <<<<
NOTE: You can only record 60 seconds at a time.
4 When you have finished recording, click the Stop button.
5 To hear what you just recorded, click the Play button.
6 To save the file, select Save from the File menu.
>>>> If you hear crackling in the playback that correlates with your handling of the cable then bad seating or a bad cable are the problem. <<<<
Adjusting recording quality
The better the quality of the recording, the more disk space the sound file requires. Experiment to find a balance that fits your needs.
1 Open Sound Recorder, if necessary (click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder).
2 In the Sound Recorder window, click Edit, then click Audio Properties.
3 In the Audio Properties window, adjust the Sound Playback quality and volume, and the Sound Recording volume.
4 Click OK.
Your new settings take effect the next time you record.
Dec 30, 2010 | Toshiba (P000257700) Microphone
Disk filled while recording/lost audio but says its still there
Often when one runs into the end of a storage medium, it becomes impossible to even transfer data,,, It seems like they often need a little bit of room to handle the headers and stuff.
When doing a recording session, it is often a good plan to have a backup recorder, even a tape unit that you can recover the data form.
I would suggest aa call to the manfacturer to see if they have any suggestion for recovery of your audio.
I would try to save the file, even if it doesn't appear to have audio at this point.
Jan 08, 2010 | Tascam DP01FX All-In-One Recording Package...
Recording a greeting
You need to be in Tam fax mode firstly.
1, {#} {0} {0} {1}:= “TAM/FAX” (default)
2,
Press {RECORD} repeatedly to display “TAM GREETING”.
3,
Press {SET}. A long beep will sound.
Speak clearly about 20 cm ( 8 inches ) away from the microphone.
The display will show the remaining
recording time.
5 When finished recording, press {STOP}.
The unit will repeat your message.
To erase and start again
Tam/fax mode again.
2 Press {ERASE} repeatedly to display “TAM GREETING”.
3 Press {SET}.
To cancel erasing, press {STOP}.
4 Press {SET}.
should be good now.
Regards
Richard.
Apr 24, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
Wont record blank cassettes? Any ideas?
it probably does need a microphone. check for an input plug on it.
Jun 05, 2017 | Spectra Hello Kitty KT2028...
iRiver H10 MP3 Player Logo
52 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
