Question about Kitchen Ranges
I cannot find the instruction manual for a HotPoint gas stove model RGB8745
  • 333 Answers
Click on this link and then enter your model #. This should help. http://genet.geappliances.com/DocSearch/Dispatcher
Posted on Dec 24, 2008
Can't seem to access Hotpoint Stove Pilot Light?
Your range uses electronic ignition, not pilot lights. For surface burners the igniter sparks when the gas valve is turned to the "light" position. All burners should spark when any gas valve is in the light position. For the oven the ignitor is also electric but does not spark but rather heats up or glows. What is the problem with your range?
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
I need the manuel for my Hotpoint stove. I can't
You can find a manual at the Hotpoint website. If you enter your model # into the box, it should bring a downloadable manual right up. To find the model number on most GE/Hotpoint ranges, pull out the drawer and it should be on the lower frame facing the front of the range. Hope this helps
http://www.geappliances.com/service_and_support/literature/
Jun 18, 2011 | Hotpoint Kitchen Ranges
Hotpoint bd35 electric oven instruction manual
Here is a link for you to download a PDF instructional manual for your Hotpoint cooker or Hotpoint oven.
how to use this service
1 click on Link,
2 click manufacturer (Hotpoint)
3 enter your model number and download the PDF file .
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Jan 28, 2011 | Microwave Ovens
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Hot Point stove oven and broiler won't turn on
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Hotpoint RGB745 Gas Kitchen Range
My gas stove top and oven will not ignite . . . do I need to worry about an explosion before it can be fixed?
Hi, If this model has standing pilot lights, you need to turn the gas off. If this is an electonic/spark ignition stove, you will not need to worry about any gas excaping.
Vic
Jul 08, 2009 | Hotpoint RGB745 Gas Kitchen Range
What does F-1 mean on the electronic display of stove?
F1 is a failed thermistor control in the control board. Board must be replaced to fix. Part is in vicinity of $120.00
May 20, 2009 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RVM1535DMCC OTR micro-has NO stove top draft.
Did you check the installation instructions and the owner's manual?
You can download GE owner's manuals and installation instructions
here.
If you still have a probme, I would call the GE Answer Center:
GE Answer Center®
1-800-626-2005
Monday - Friday: 8 a.m. - 10 p.m. ET
Saturday: 8 a.m. - 7 p.m. ET
Closed Sunday.
Mar 05, 2009 | GE Hotpoint Over-the-Range Microwave
HOW DO I CLEAN IT
Ineed amanual for my hotpoint oven so i can clen it
May 04, 2008 | Hotpoint RB757 Electric Kitchen Range
Kitchen Ranges Logo
115 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
