Ford focus 2010 - fuse box located underneath glove box passenger side. two black turn screws - turn 1/4 turn to release white fuse box. Cigaretter lighter fuse is fuse number 109 (difficult to see as white text on white box!!!)
Fuse is 20A fuse located first left on second row as indicated in diagram.
On this site you find fuse box diagram and description for Ford Focus mk3
http://www.autogenius.info/en/ford-focus-mk3-2011-box-fuse-diagram/
SOURCE: cigarette lighter fuse location
The cigarette fuse is located in the battery junction box under the hood, it is fuse # 10 and is a 20A fuse, open the hood and find the box it is on the passenger side towards the back of the compartment, it is 10th in line on the top row, also you can check these fuses without removing them through the clear plastic top so that should make things a little easier too, hope this helps
SOURCE: Need to change the fuse of the cigarette lighter
For the cigarette lighter fuse on uk models ford focus there is another 'hidden' fuse box behind the glove box.
Just unscrew three screws at the hinge of the glove box.
Replace fuse 35 which is a 15amp fuse.
Hope this helps .
SOURCE: fuse for 1999/2000 ford focus diesel estate cigarette lighter
its fuse 46 and it should be a 15 amp according to the manual as i have the same car as you hope this helps
