Question about Elna Quilter's Dream 6003Q
Elna 6003Q Will not snap out of Bobbin Winding Mode
How do I get it out of Bobbin Winding Mode so other functions will work?
  • skgipson Feb 09, 2009
    My machine will not snap out of bobbin winding mode.
I gently took a screwdriver and press the plastic base of the bobbin spindle to the left, I guess that the spindle base was not making a good connection, so the computer could not tell if it was still in that mode.  It worked for me. thank-you for your other insights to this problem.
Posted on Feb 28, 2009
Why does display read "WINDING BOBBIN" and won't clear?
This video may help:
Winding an Elna bobbin
Perhaps the bobbin winding mechanism has not been released. (She unsnaps the bobbin when finished winding.)
Aug 31, 2015 | Elna Quilter's Dream 6003Q
Elna sewing machine 7000 geting bobin won't go through the feed dog
sorry, not sure I understand your problem. can you elaborate?
Have you got the correct Elna bobbin for your machine? check your manual, it should have an image of the bobbin, the 7000 was one of the last Swiss made Elnas and although a computerised machine, it still tool the Elna metal bobbin with 7 holes on one side only. If you are using another bobbin in the shuttle, it may not function correctly.
if you can add some more info I will try to help you further.
Oct 29, 2012 | Elna Quilter's Dream 6003Q
I have the Elna 6003 quilter's dream machine. The problem is that it is stuck in the "bobbin winding" mode and will not allow me to change stitches. I have tried turning it off and turning it...
Does this have a bobbin winder post and stop at the top right. If so, is the bobbin winding post moved back to normal position or up against the post?
Being computerised, if you have tried powering it down and all the settings are correct, then it might want a trip in the car to see the technician to sort out this fault.
Apr 06, 2011 | Elna Quilter's Dream 6003Q
Stuck on bobbin winding,cannot change stitches
Refer to the troubleshooting section of your manual.
If this does not help, you will need to take the machine in for service.
Feb 27, 2010 | Elna Quilter's Dream 6003Q
Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Dec 26, 2008 | Elna Quilter's Dream 6003Q
Bobbin winding
On the top left side of your machine is a round thread guide which is supposed to create tension and guide the thread. Sometimes the thread comes out of this thread guide and causes the problems you are experiencing. Wrap the thread around this guide one time and you should have your problem resolved.
sewman7
Jul 07, 2008 | Elna Quilter's Dream 6003Q
Elna 6003 just stopped working
Something caught inside the machine and jammed the mechanism. It blew a fuse to protect the circuit board. A competent Elna or Janome Dealer should be able to get you machine going in no time.I don't know of any reason to have trouble finding parts for this machine.
sewman7
Jul 05, 2008 | Elna Quilter's Dream 6003Q
Bobbin winder is stuck
It seems that the bobbin winder sensor needs adjusting and is best done by a service technician with the appropriate service manual to ensure correct parameters are achieved..........to locate your nearest Elna dealer, try ElnaUSA .....here
Feb 16, 2008 | Elna Quilter's Dream 6003Q
Sewing Machines Logo
197 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
