Question about Canon PIXMA iP4000 InkJet Photo Printer
Magenta won't print?
Hy guys... I experiance a problem with my pixma ip4000 My english is not very good so... here it is: The catridges are not original... (i think this is probably the problem) Other colors are fine, but magenta is not empty and still i doesn't get it on paper... I try cleaning,deep cleaning... taked the colors out and wipe the print nozzels but no effect... Can I rescue my pixma? :) Thx...
    Genius:
  • 2,985 Answers
Take the Caridge out and stand on damp tissue overnight -then see what happens come back and tell us
Posted on Aug 05, 2007
Printer failing to print colours properly
may the catridge is not working fine i thik you did all the cleaning test but you fail i advise you to use new catridge then try it will works
have a nice day and dont forget to rate please.
Feb 12, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My canon pixma ip4000 has stopped printing. It is going through the motions but the paper is coming out blank with nothing on it.
Hi
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your Canon PIXMA iP4000 InkJet Photo Printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Or possibly a faulty cartridge.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the Magic Inkjet Flush kit to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Nov 23, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Magenta not working when printing colors
try to wipe it in a wet cloth to remove the clogs on the nozzle that avoid it from jetting...load again your catridge on the carrier or cartridge holder....
and run maintenance page on it ...go to your printer panel and select maintenance and then select clean printhead..to print a maintenance page..or maybe your magenta has have a low ink condition..
thank you for using fixya..
good luck..
May 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Color not coming out right when printed
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be  dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the  catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10  Seconds......
Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same  way........
Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a  Copper plate on it with small boxes just clean that copper plate with the Dry Paper
Towel..........
Know insert both the catridges inside the Printer... Good Luck
Jan 28, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000
one trying is here
make sure you remove the sticker in catride ,it placed in near head of the ink catridge,and it marks so that
Mar 02, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
IP4000 won't print anything except magenta
Hi make sure that the cartridges are fully installed and that you have taken the packaging completely off. Failing that there are two possibilities.
1 Print cartridges faulty or refills
2 Faulty Print cartridge head.
Thanks hope this is of some help
J
Dec 27, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Problem with color quality - Canon PIXMA iP4000
i had this problem... its the ink! Check you are using magenta and NOT "photo magenta", and also that you are using "cyan" and NOT "PHOTO cyan"... basically photo cyan, photo magenta and photo yellow are not designed for the ip4000, if you check the smallprint on the box it does not list the ip4000.
This exact problem happened to me and it was driving me crazy. I think the "photo" versions of the inks are for printers that take two tanks of each colour, and the photo version is used for very subtle colours... so if you are ONLY using these inks, photos will appear washed out, yellow etc
Oct 30, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Pixma iP4000 problem
the printhead is shot. I've replaced my printhead twice on my pixma ip6000D in just over two years.
Aug 20, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
91 people viewed this question
Clive
Clive
old marine
old marine
