Question about ViewSonic VE710b 17" Flat Panel LCD Monitor
Computer turns on and off repeatedly
When the power button is pressed on emachines computer, the computer comes on for less than a second, beeps, shuts off, then repeats the same thing over and over. The monitor and other hardware work fine. Any help would be greatly appreciated! Thanks!
    Master:
  • 413 Answers
It sounds like your ram or video card is not functioning. You can try some different ram and video card and that is where i would start. This is probably not going to be an easy fix so be ready
Posted on Dec 24, 2008
My hp touchsmart310 PC will switch on but there is nothing on the screen ?
You can perform these steps even though the screen is blank.
  1. Turn off the computer, and then remove the power cord.
  2. With the power cord disconnected, press and hold the power button for five seconds.
  3. Reconnect the power cord, and then turn on the computer.
  4. Repeatedly press the F10 key about once every second for five seconds after turning the computer on.
  5. Wait five seconds.
  6. Press the F5 key. This restores the default settings of the BIOS.
  7. Press the Enter key. This accepts the changes.
  8. Press the F10 key. This opens the Save and Exit window.
  9. Press the Enter key. This saves the changes, exits the BIOS, and then the computer restarts.
  10. After the computer restarts, the screen should display the HP logo.
Hope it helps!
Aug 11, 2014 | HP Touch Smart Desktop Computer "brand...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
Power Switch comes on but moniter goes back to sleep.
use external monitor to setup internal monitor setings
Nov 10, 2012 | eMachines T3508 PC Desktop
Emachines t2042
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted,but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static ChargeBuildup. Remove the Power Cord, then Press and Hold the power button for30 seconds. After 30 seconds plug the power cord back in and hit thepower button to see if it boots. Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
Jun 07, 2012 | E-Machines eMachines Desktop PC
Computer wont come on
Did you installed the fjsecs Security Panel Application????...
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/lifebook/LIFEBOOK/E-Series/Security.htm
Read this manual, maybe can help you.
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/T4220_UG_B5FJ-4091-02EN-00.pdf page 26
To unlock the machine is completely necessary that you remind the password...
Just pres the display buttons in the order that you selected in the program.
http://static.phing.com/listings/48/481970/2882-8dc5j0_l.jpg
The buttons next to the power button at the right of the display.
There is a microphone symbol next to the buttons....
1 = a and arrow down
2= b and arrow up
3= rotate screen button
4= fn button
ent = alt.
If you selected http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/lifebook/LIFEBOOK/E-Series/images/Screenshots/Image5.jpg
Example:
If you checked the boxes 1234 pres the buttons 123and4 at the same time.
next press ent (ent is next to power button)....
when you press any button that make a beep sound...
If the pass is wrong it will beep constantly for one minute..
other example: 1 - 2 - 14 - 4
in the first just 1 press 1
in the second 2 press 2
in the third 1 and 4 press 1 and 4 at the same time
in the fourth 4 press 4
finally press the button ent.
I hope you can access to your laptop....
Feb 06, 2012 | Fujitsu LifeBook T4220 Tablet PC
Compute turns on, lights light up, and fans move, but there are no beeps or bios showing up.
Computer turns on but no display. This issue is commonly caused by electrical static on the motherboard. Try doing a power drain.
If this computer is a laptop:
1. Turn the computer off by pressing the power button for a bout 5seconds.
2. Take the battery out of the computer.
3. Unplugged the ac adapter.
4. Press and hold the power button for about 30 seconds. (without any power source)
5. Put the battery back in and plug the ac adapter back into the computer.
6. Turn the computer back on.
If this computer is a desktop:
2. Unplug the power cable from the computer.
3. Press and hold the power button for about 30 seconds. (without any power source)
4. Plug the power cable back into the computer.
5. Turn the computer back on.
Thank you for choosing FixYa! have a good one!
Jun 02, 2011 | Computers & Internet
Making beeping sound when i start up the computer
A beep sound can be due to memory problem.
First use the following steps:
1 Turn off the system and disconnect power cables
2 Press and hold the power button for 30 seconds
3 Reconnect power cables and try to turn it on.
If you still get a continuous beep sound, the next step will be to re-seat memory modules (after turning off the system).
Mar 08, 2010 | E-Machines eMachines Desktop PC
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
Wont boot/start
Turn off power, unplug, hold power button for 30 seconds, take out memory, or if you have more than one stick only take all but 1, plug the power back in and start the computer. If a screen pops up that bios has changed press F2 to continue once computer is completly loaded click start, shut sown, unplug power cord again, hold power button 30 seconds, insert other memory and restart
May 13, 2009 | E-Machines eMachines Desktop PC
ViewSonic VE710b 17" Flat Panel LCD Monitor Logo
142 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
