Question about Panasonic Lumix DMC-FZ20 Digital Camera
DMC-FZ20 dismantle help...
I too have my FZ20 suffering from intermittent button pressing, freezing and multiple menu pressing when navigating. Nothing a sharp jolt wont fix but this isnt good for the optics... I have undone the rear case screws but cant work out how to disengage the cover from the very top between the flash pivots...HELP! I am sure just reseating the ribbon cables will solve my issues but cannot get in there yet!! Any help appreciated!
It's not clear from casual inspection, but the spring is a separate sheet of stamped metal and is not connected to the shoe. If you can lift up the forward edge, it should slide right out of the shoe.
Posted on Jun 01, 2007
    Problem Solver:
  • 4 Answers
I had the same problem trying to get my camera open. I found this link that might help. The FZ10 and FZ20 have similar bodies. http://www.eserviceinfo.com/index.php?what=search2&searchstring=FZ10++FZ20 I was still stuck with the top of the camera because of the hot shoe. I finally used a small screwdriver to slide the spring back. It exposed a few more screws that had to be removed. Unfortunately I reseating the ribbon cables did not help in my case, but good luck Jid
Posted on Apr 22, 2007
Cell freeze 3 rows together at a time.
Freeze a Row in Microsoft Excel
Microsoft Excel 2010 can freeze, or lock, a top row as you scroll down the worksheet.
For example, you may need to keep the top row of column titles visible at all times.
The "View" tab on the command ribbon contains the "Freeze Panes" button in the "Window" group.
A single row or a range of rows can lock through the "Freeze Top Row" or "Freeze Panes" options.
Open the Excel worksheet.
Click the top row heading.
The row heading displays a number just left of the first column of cells. The selected row appears shaded.
Click the "View" tab on the command ribbon.
Click the "Freeze Panes" button in the "Window" group.
A list of options appears.
Click the "Freeze Top Row" option.
A black horizontal line appears on the worksheet.
This line indicates the locked row that stays on the screen as you scroll down the worksheet.
http://office.microsoft.com/en-us/excel-help/freeze-or-lock-rows-and-columns-HP010342542.aspx?CTT=1
Freeze or lock rows and columns
also
Use Freeze Panes in Excel
Scrolling down to look at a number and then scrolling up to make sure the number you looked at is under the header you expected is not an efficient way to view a spreadsheet.
The Freeze Panes feature of Excel allows you to freeze the labels of your data in place while you review the data.
Follow the instructions in Section 1 to freeze the top row or the left column.
Freeze multiple rows, multiple columns, or rows and columns, by following the instructions in Section 2.Freeze the Top Row or Left Column
Open the Excel spreadsheet.
Navigate to the "View" tab on the top menu.
3 Click on "View," then click on "Freeze Panes." A drop-down menu opens.
Select the "Freeze Top Row" option to freeze the top row.
5
Select the "Freeze Left Column" or "Freeze First Column" option to freeze the left column.
6
Freeze the top row by using the keyboard and sequentially pressing the keys "ALT, W, F, R." Ignore Steps 3 through 7 if using this choice.
7
Freeze the left column using the keyboard by sequentially pressing the keys "ALT, W, F, C." Ignore Steps 3 through 7 if using this choice.
8
Unfreeze panes by repeating Steps 3 through 5 and selecting "Unfreeze Panes" or sequentially press the keys "ALT, W, F, F."
Freeze Rows and Columns, Multiple Rows, Multiple Columns, or Multiple Rows and Columns
9
10
Freeze column(s) and row(s) at the same time by selecting the cell to the right of and below the location you want to freeze.
11
Freeze multiple rows only by selecting the cell in the left (first) column below the rows you want to freeze.
12
Freeze multiple columns only by selecting the cell in the top row to the right of the columns you want to freeze.
13
14
15
Select the "Freeze Panes" option. You have now frozen the columns or rows, or columns and rows you designated.
16
Freeze panes using the keyboard by sequentially pressing the keys, "ALT, W, F, F." Ignore Steps 5 through 8 if using this choice.
17
Unfreeze panes by repeating Steps 5 through 7 and selecting "Unfreeze Panes" or sequentially press the keys, "ALT, W, F, F."
http://office.microsoft.com/en-us/excel-help/freeze-or-lock-rows-and-columns-HP001217048.aspx
http://office.microsoft.com/en-us/excel-help/demo-hide-or-unhide-rows-and-columns-HA010241040.aspx
Hide or show rows and columns
Aug 14, 2013 | Microsoft Office Computers & Internet
I have a panasonic lumix DMC-FZ20 camera that i installed an 8g memory card but it says memory card error
The DMC-FZ20 works with MMC and SD cards, 2GB or smaller. Your 8GB card is an SDHC card, which fits into the slot but is electronically incompatible.
Feb 22, 2013 | Panasonic Lumix DMC-FZ20 Digital Camera
DMC-FZ20 won't stay on after power up
In the camera setup menu there is an option which says power saver......increase the time frame in power saver...it will solve the problem
May 30, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Camera Frozen
Try to set your shutter speed you can do this by selecting (S) at the mode dial....
Thanks
May 25, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Lumix DMC FZ20
Did You try checking the sd card or turning it on and off
Nov 20, 2017 | Panasonic Lumix DMC-FZ20 Digital Camera
DMC FZ20 lens diameter?
You can put on 72mm filters, but you have to use the extension (sorry, but my english is not the best, and i don't know how it is called..)
Oct 19, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic FZ20 does not switch off, menu buttons dont work
Same thing happened to mine 6 months ago. I paid $130.00 for repairs while still under warranty. Waranty is for parts only. Then I left the camera on the roof of my jeep overnight in the rain. Same thing went wrong. It was past the 60 day repair warranty so I took it apart myself and put it back together. It works fine now. I suspect it was an intermittent contact in the ribbon connector to the rear control unit.
Dec 28, 2006 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Lumix DMC-FZ20 Digital Camera Logo
234 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
