Question about Vizio L30WGU 30 in. HD-Ready LCD Television
Turning off closed captioning on Vizio
Hi - I saw your post on fixing this problem. However, I don't see the 4th menu (I think it looks like a sattelite) that lists cc. Any other ideas that you think might fix this?
4 Suggested Answers
SOURCE: Closed caption wont turn off
I have a Vizio VX37L that i purchased on 12/26/08 and I had the same problem by 1/4/09. My five year old son loves to futz around with buttons and switches and he somehow enabled closed captions from the front of my Motorola digital cable box (I had it hooked up to the Vizio via HDMI 1.)
What you need to do is turn off your cable box and leave the Vizio on. Hit the "Menu" button on the front of the cable box and that should bring up a setup screen on your TV. Using the down cursor button on the front of the cable box, go down to the "Close Caption" section on the setup screen. It probably says "Enabled." Click on the right cursor button to disable CC and you should be good to go.
Posted on Jan 05, 2009
SOURCE: My Vizio 37' flat Screen TV Closed Caption wont turn off
If you have a digital cable box, turn off the box but leave the TV on. Hit the "Menu" button on the front of your cable box and a setup menu should come on. Use the cursor buttons on your box's front panel to go down to the "Captions" option, which is probably set to "Enabled" and hit the right or left cursor button to change it to "Disabled." That should solve your problem.
Posted on Jan 10, 2009
bshldn
  • 736 Answers
SOURCE: 2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Posted on Nov 09, 2010
How do get closed caption Vizio VF550M 55 in. LCD HDTV?
Closed Caption availability may depend on the source. To enable caption viewing, press Menu (on the TV or the remote). Navigate to the Setup menu with the Up/Down arrows on the remote or the Channel Up/Down buttons on the TV. Once Setup is highlighted, press the Menu button again. Repeat the up/down navigation to the CC menu and Menu to select. The first option should be On/Off. Now use the left/right arrows on the remote (or volume up/down buttons on the TV) to choose the desired CC state. Press Menu to save or Last to cancel and return to the previous menu. Press after pressing Menu to return to the previous menu. If your content is from a digital source, you can make adjustments in the appearance of the captions by navigating to those sections of the CC sub-menu. If you would like some idea of what the screen will look like as you navigate the On-Screen Display, see the manual on Page 41. Vizio makes the manual available on their support page. The direct link to the manual is cdn.vizio.com/documents/downloads/hdtv/VF550M/155Manual.pdf . (Note: you'll need Adobe Reader or a similar program to access the manual.)
For some content, you may need to enable the captions at a set-top box (cable/satellite receiver/etc.). In that case, consult the manual for those devices or post a comment with the make/model for additional help.
I hope this helps.
Feb 13, 2015 | Vizio Televison & Video
My closed captions all channel is displayed on my vizio tv. I can't get it to go off. I use verizon fios my box doesn't have a menu button on it. Any other suggestions?
Closed captioning is selected during initial set up of your Vizio TV. If you return to that procedure, you can turn off closed captioning.
Dec 07, 2014 | Vizio Televison & Video
My closed caption is on and I can't turn it off. I don'want the writing on the screen
Did you try turning it off with the closed caption button on the remote? Its labelled cc. If you dont have the original Vizio remote you will need to go into menu-settings and find the closed caption and turn it off there
Oct 24, 2011 | Vizio L37 Television
My mother in law needs to have the words printed out on the bottom on the screen, and we don't know how to do it. Help. We tried set up but it didn't work.
go in to the menu and find closed captions and turn them on. sometimes there is a button on the remote that says CC if not look in the menu under settings or audio
Aug 19, 2011 | Vizio Televison & Video
My Vizio VA19L 19'' LCD Television's closed captioning isn't working. The closed caption isn't on the settings menu either. How can I get closed captioning on?
Just press the CC button on the remote. Some TV stations may not send out CC data. Pressing the CC button many times will cycle thru all the options including OFF.
Mar 05, 2011 | Vizio VA19LHDTV10T 19 in. LCD TV
How to turn closed caption off?
If the cc button on your Sharp remote control isn't turning them off then the captions may be coming from your cable box. The hidden menu to access closed captioning on the cable box is usually found by turning it off and then (yes I did say turn the cable box off) then press the menu button on the front of it immediately after turning it off. Then you navigate down to captions and disable them. When you turn the cable box back on the captions should no longer be there.
Feb 01, 2011 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
I cannot access the closed caption feature on my Vizio VO42L help?
Look at the remote control: (page 14 of the user manual)
CC
/Stop – This button will select the Closed Caption mode. The
options are OFF, CC1, CC2, CC3, CC4, TEXT1, TEXT2, TEXT3 OR
TEXT4. Additionally, this button stops the CD, DVD or VCR when the
component is activated with the remote control.
Download user manual here:
http://tv.manualsonline.com/manuals/mfg/vizio/gv42l.html
Please post back what you find.
Nov 15, 2009 | Vizio GV42L 42 in. LCD Television
Close caption problem
Use ur remote turn off CC functions on the remote.
Or go to the menu go to the caption turn everything off like Text or CC1 CC2.
Sep 23, 2009 | Vizio VW42LF 42 in. LCD HDTV
May 07, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L30WGU 30 in. HD-Ready LCD Television Logo
163 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
