Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Squealing noise Has a squealing noise when washing
    President:
  • 373 Answers
This is a problem with the drive belt tension.needs to be adjusted.sometimes the problem might be solved by balancing the machine on ground.
Posted on Dec 24, 2008
  • bgraniela Feb 12, 2011
    Will like more details on disassembling and tension adjustment or parts that may need to be replaced.
Our washer is making squealing noises while washing, sometimes.
I should hope the reason is a loose or slipping belt.
Because the belts are never where you can see them, you will not know their condition until they break, or in a few cases, they squeal.
The belt is by far the most common cause of squealing.
God bless your efforts.
Feb 26, 2018 | Washing Machines
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Squeals when hot water inputs
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jan 10, 2010 | LG WM2101HW 4.0 cu.ft. Washer
Washing machine makes squealing noise during the
when belt was changed did you find the old belt to be oiley . it maybe leaking oil from trans . and the belt will keep failing till oil leak is corrected.. mm
Dec 14, 2009 | Washing Machines
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Squealing noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
98f
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer squeals during wash & rinse cycles.
It sounds like you're brake stator & rotor is worn and merit replacement, it would also be prudent to replace the thrust bearing as well since you'll be in the same area for the repair. The way to verify is to place the unit in spin & allow it to reach speed then open the lid. If it squeals then the repair would need to performed, if it does not then further troubleshooting would be needed. Hope this helps... Bill
May 29, 2009 | Maytag PAV2300 Top Load Washer
Washing machine makes noisy squeal when pumping out water
i turn the dryer on it goes for a few minuts and then it fuses all the power points
Apr 03, 2009 | Fisher and Paykel GWL11 Top Load Washer
Squealing noise
possible causes are:
bra wire stuck in tub and rubs against the drum and squeals when on spin.
lip seal at front of bearings squealing - this is a difficult repair
Sep 02, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
166 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
