Question about HP PSC 2355 All-In-One InkJet Printer
All of the lights are blinking & screen says "memory trashed"
All of the lights on the front panel of the 7210 are blinking and the screen says "Assert: Memory trashed? For several months the display will show garbage on it after it has sat for a while.  Restarting it fixes it for a few hours - although the carriage gets stuck half the time.  Today, for the first time I have recieved the "Assert! Memory Trashed?" error.  Since it is a question, I'll just answer no - that will fix it I'm sure.
  • 2 more comments
  • Anonymous Dec 27, 2008
    i have the same thing on model Hp 1610xi
  • sosezshe Feb 27, 2009
    I also have a PSC 2355 that I tried to reinstll on my lap top. The mesage on the LCD reads Assert! Memory Trashed? and the lights are frantically blinking. I tried turning the machine off to reset it, no luck.
  • bdw33 Mar 23, 2009
    Same thing happened to me!!!
  • Anonymous Mar 25, 2009
    The problem occured on my HP 6210 All in one. I rebooted it and for now it is resolved. but who knows if it won't happen again.
With the printer on, unplug the power cable.
Hold down the cancel and "ok" keys on the printer.
plug the cable back in.
Answer the setup questions.
Turn on and off as required.
TH
Posted on Nov 19, 2011
SOURCE:
I have a Hisense led tv model F39V77C.
Yeah, replace the set since it appears to be trashed. But if you have a few bucks lying around you might want to try replacing the unit's power supply to see if that resolves the many issues you have.
Jan 03, 2017 | Hisense Televison & Video
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Regards,
Jdvillanueva
Nov 24, 2011 | Mitsubishi WD-60737 TV
When i am starting my nokia 7210 supernova , it is only showing a blank white screen and again shuting down ???
hi there, you need to re program your 7210, due to full memory thats why your cellphone cannot initialized and it will shutdown automatically, pleas bring it to a service cellphone repair shop to re program it. thanks
Apr 23, 2011 | Nokia 7210
How to recover 7210 memory card password
how to recover NOKIA 7210 memory card password. I forgotten the password
Apr 30, 2010 | Sprint NOKIA 7210/ 6100/2270/3585 W/On&Of...
HP Officejet 7210 All-In-One Inkjet. Arrived at
In absence of another solution, I finally switched the Officejet off. No idea if that "trashed" the memory or anything else, but it's working again - for now.
I am surprised that nobody, especially HP, has a real answer (let alone a solution) for this problem, when the same question about the same model has been asked since 2007 or before! I'll keep hoping, because the consensus seems to be that the "Assert! Memeory trashed?" WILL happen again.
Dec 02, 2009 | HP Officejet 7210 All-In-One InkJet...
Samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Jan 10, 2009 | Samsung DLP HL-P5663W 56" TV
Power light blinks
Circuit board problem pawer supply
and or horilz deflection HV
Requires proffessional Service
May be worth repair. you could
get an estimate, and then decide
whether to throw it away or not
Nov 24, 2007 | Samsung LTN1565 15 in. HD-Ready LCD...
HP PSC 2355 All-In-One InkJet Printer Logo
803 people viewed this question
Clive
Clive
Thomas F. Schneider
