I received a new XP laptop today! When tried to "search for available wireless networks" I could not because Intel software kept taking over from Windows XP, so I removed/uninstalled my intel wireless network adaptor -woops! I can connect to the internet using a wired ethernet connection. I am looking for the drivers that will enable my intel wireless network adaptor, on a Lenovo F31 laptop to work properly, and connect to my home network. I hope you can help, Yours sincerely, Suleman Pervez
    Guru:
  • 829 Answers
Hi , Do you have a wireless router ? Did you disable the wireless network , If yes you need to enable . You need to check if the wireless driver is installed properly for that you need to RightClick My Computer+Properties+ Hardware + Device Manager + Click On Network Adaptors . If Yes the n you need to Right Click My Network Places+ Properties and check for Wireless Status + Right Click Enable.
Posted on Dec 25, 2008
How do you configure a linksys wireless-b WPC11 notebook adapter to connect to available wireless connections?
let me tell you its very easy.
Follow these steps to connect your Linksys adapter to available wireless connection:-
1.With this adapter you must have received a disk of driver for this adapter.
so install the drivers disk first.
2.Once the driver disk install then now you can search for available wireless network name.
To search wireless network in xp:-
start>>control panel>>network connection
now look for your wireless network connection.>>>right click on it>>>left click view available wireless network>>>here you can see the available wireless network name and now try to connect to your network name
Follow these steps for vista and window 7:-
Click on start>>Above start you will have search box>>in the search box type connect to
Apr 08, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
How do i reset the password to one i want for my wireless computer connections
I don't know which software you have, or which version of Windows you are using. On XP, you can right click on your wireless icon on bottom right of your screen, then select "view available wireless networks". The resulting screen will allow to look at the connections you have stored, and remove (delete) connections. Delete the connection you want to change, and then do a search for available networks, and when it asks you for the password, put the new password in.
Aug 13, 2010 | Computers & Internet
Unable to use the wireless setup wizard - I am trying to connect my pc with my wireless printer. When I try to use the setup wizard on the pc it says depending on the wireless software installed on this pc...
The Wireless Network Setup Wizard and the View Available Wireless Networks feature both rely on the Wireless Zero Configuration service to provide their functionality to Microsoft Windows XP Service Pack 2 (SP2) and Microsoft Windows XP Table PC Edition 2005. If the Wireless Zero Configuration service is not available, you receive an error message that directs you to this article. This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Click Network Connections.
  3. In Network Connections, click to select your wireless connection, and then clickChange settings of this connection.
  4. On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
To start the Wireless Zero Configuration service, follow these steps:
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then click OK.
  2. Double-click Wireless Zero Configuration.
  3. In the Startup type list, click Automatic, and then click Apply.
  4. In the Service status area, click Start, and then click OK.
If you receive an error message when you try to start the service, see the "References" section for more troubleshooting information.For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 815485 Overview of the Wi-Fi Protected Access (WPA) security update in Windows XP 313242 How to troubleshoot wireless network connections in Windows XP
Feb 26, 2010 | Acer Aspire One PC Notebook
Can't power on wireless adapter. worked fine since
my laptop lenovo 500 cant find any networks, have done the usual searches and checks but to no avail. any ideas
Feb 13, 2010 | Lenovo 3000 N500 Notebook
Intel ProSet Wifi software can't connect to network
You need to manually add the network using your intel pro set utility. Or just switch to wzc.(wireless zero configuration). How to do it? just click start - go to run - type in services.msc - then look for wireless zero configuration on the list - right click on it then click start.
Then look for the wireless network connection icon on the system tray (that's in the bottom right hand corner of your screen). right click on it then select view available wireless network.
note: if you'll be getting the message "windows could not configure..." click change the order of preferred networks(that's in the same window where you're getting that message) then check the box that says "use windows to configure my wireless network settings" then click ok. after that go back to view available wireless networks then you should see your network now.
note: if you're using a corporate laptop where you don't have admin rights on it you need to use the intel pro
Dec 28, 2009 | Linksys Wireless-G WRT54G Router
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
Intel proset wireless 3945ABG no adapters found
You need to disable the Windows Wireless manager in order for the Intel app to take over control of the wireless adapter.
Start
Run
"services.msc"
Find a service called "Windows Zero Wireless Configuration". Stop it. Set it to disable.
Try rebooting the machine and the Intel app should work.
Mar 22, 2009 | Computers & Internet
Wireless accessing problem with Lenovo Y410 using broadcom
If you have not been able to check this at all yet, please uninstall anything you install for the NIC and reinstall drivers... after that you can also try making sure the DNS is set correctly...
http://forum.dreamhosters.com/troubleshooting/76452-Is-my-DNS-correct.htm
Dec 06, 2008 | 3Com (3CRPAG175) 802.11a, 802.11g/b...
Cannot find network 1394 network adapter nor the standard Network Adapter connection
Try having a System Restore on your computer back to the date before you installed the wireless HP printer device and software.
Sep 13, 2008 | Computers & Internet
Computers & Internet Logo
158 people viewed this question
Alun Cox
David Payne
David Payne
