Question about Whirlpool WHP1000SQ 10" Pedestal In White
Whirlpool WHP1000SQ 10" Pedestal this came with no instruction where can i get on line instruction
  • 640 Answers
If you want to put the pedstal on unit..lay unit on back.pull draw out of pedestal ,than lay pedestal on back then put the bolts or screws in though pedestal ,,and stand ...
Posted on Dec 25, 2008
Will LAB2700LQo pedestal fit my Kenmore model 110-47532602 or 1108752601
Even though the Sears brand is made by Whirlpool, the 110 series is an exclusive line. IT is not likely to fit. You will have to measure the base and mounting holes on the pedestal and the machine.
Jun 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Problem installing a pedestal on a cabrio dryer
We'll be glad to further review your concerns. Please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with the website you reached out to us on (fixya), brief description of your concern, your name, address, a phone number and best time to reach you along with your model and serial number.
Jan 10, 2018 | Whirlpool Dryers
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
Is samsung pedestal model number WE356A5W/XAA compatible with samsung front loader washer wf220anw?
The correct pedestal for the WF220ANW washer is WE357A7W . The WE356A5W is a slightly different size to secure it to the washer (14 2/5 X 27 X 28 7/10 In). The WE357A7W is 27"(W) x 14"(H) x 28.5"(D). The holes for the screws will also not quite line up.
I hope this helps.
Jul 11, 2011 | Washing Machines
Need exact dimensions of duet washer & dryer bought in 2006. Also how to prepare for moving same appliances.
Basic measurements for washer and dryer with door closed and not on optional pedestal(s) are 31.5" deep (front to back), 27" wide, (left to right), and 38" high. For installation and usage consider the leveling feet, use of pedestal(s), water hookups, drain hose for washer, and vent (exhaust) hose for dryer. You may want to position the washer on your left, and the dryer on the right due to hinge location, and for ease of transferring laundry from one machine to the other. Depth of washer (front to back) with door open 90 degrees is 50.5" and the dryer is 51.5". At the factory, four (4) shipping bolts are attached to the back of the washer to secure the drum for shipping. These should be re-installed prior to the move, (if you still have them). To see the supporting documents, go to; http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/ewpl_mic_604_021.pdf
I hope this helps you as well as others. Please rate my answer. Handiest1. 10-1-10
Oct 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I test my whirlpool duet? There are certain buttons you push and I lost the instructions can anyone help
are you trying to run diagnostics?With the machine off, hit any button (other than pause/cancel) hold it for 3 seconds, let off for 3 seconds. repeat 5 times or until machine comes on.
Nov 08, 2009 | Whirlpool WHP1500SU 15.5" Diamond Dust...
Whirlpool pedestal w/ Kenmore Elite HE3 washer
no - the base is a different size.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 19, 2009 | Kenmore 15.5 in. Pedestal
I have a venting question for a new Whirlpool 9550 steam dryer
The vent must remain the same diameter all the way out. Previously installed vents do not often line up well. To get the dryer closest to the wall the bottom method sounds like the best shot. I would build a frame from 2x6s so you can design it exactly to your purpose. A purchased pedestal will still have some limitations.
eric
Jul 02, 2009 | Whirlpool WED5800S Electric Dryer
Water
Make sure the drain line is not plugged. Check the sewer line too.
Jan 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
171 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
