Question about Polaroid TLA-01511C 15 in. LCD Television
When I turn the TV on there is a picture for a minute or less.
The picture goes off but the sound is fine. When I turn the TV off and then on again it does the same thing.
  • 1,031 Answers
Just take a close look at the screen with a Flashlight and see if you can see some sort of picture like a ghost of an image. If this is the case, the backlight has failed.if none then probably the back light inverter board has failed and need to be replaced.
Posted on Dec 24, 2008
    Scholar:
  • 61 Answers
I wonder what inputs you are using? The first thing to check is the cable that connects to your T.V. If it is an RCA cable, the one that has Yellow, red and White cables, then try to wiggle or replace your yellow cable and see if that helps. Also, try to connect it with another device to see if it is the input for just that device. If the input for another device works and not the one you are trying now, then it is the cable or possible the a short on the mother board for that input device. In which case I would buy a converter to bring the device that you can hear but not see into a different input so that you don't have to spring for a repair bill.
This T.V. has RF (Cable input), RCA or Component Inputs, and VGA or a computer input, so if you have a computer you can hook up to it to test it, that is what I would do if there are no other devices, i.e. DVD player or Cable/satellite.
    Genius:
  • 1,011 Answers
Please provide brand name and model no.
thanks
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
TV picture goes off after 20 minutes
there are bad solder connections on the pictury tube drive module. have it fixed at a repair shop.. the tech will be mystified that you know what the problem was..lol..
Nov 12, 2009 | Televison & Video
Picture goes out right after turning on, have to
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
Sep 24, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
TV TURNS ON HUMMING SOUND FOR ABOUT FIVE MINUTES AND GOES AWAY
go in audio section and select mono instead of stereo or sap
Sep 18, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Great sound no picture
When I turn my tv on there is one certain channel that goes black after watching less than 5 minutes. this might be due to electronic tuner or loose contact in that particular section. 100% problem will be solved thanks
Sep 09, 2007 | Sanyo DS24205 24" TV
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
Polaroid TLA-01511C 15 in. LCD Television Logo
26 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
