Question about LG 32LG30 32 in. LCD HDTV
LG37LG5020 Our remote control batteries died, so we used the side panel buttons for a while. This morning, after our son used his Playstation on the TV, the TV won't programme channels in and is saying to check the antenna connection. The antenna is still connected as it was yesterday, when it was working fine. TV works fine with the Playstation, just won't programme channels (autotune)... Have done a factory reset. All advice very welcome!
  • 88 Answers
Hi. that:s be reset factory could do. if no you need a technician . good luck!
Posted on Sep 07, 2012
SOURCE:
welcomejee
  • 10594 Answers
SOURCE: Remote problems
Replace batteries of your LG remote.
Posted on Oct 11, 2008
  • 3 Answers
SOURCE: LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Posted on Jul 30, 2008
  • 4 Answers
SOURCE: LG TV no longer responds to the remote control..
I have had the exact same problem with my 47LG70 after 13 months of use. I changed my remote control sensor but it did not help. Before you do that, try something simple which seems irrelevant. On this website, others have posted success by plugging in any standing set of headphones into the remote control or headphone jack on the rear TV panel. This solved my problem. So I proceeded to thoroughly dust all of the input/output component jacks on the rear and side of the TV with an air-can. This solved my problem and I do not need to have the headphones plugged in. So try these two things before changing the sensor.
Posted on Jan 23, 2010
  • 32 Answers
SOURCE: LG42PC3D TV - No remote control. Manual control works.
dont blame the receiver yet, the problem mostly comes from the remote control. it may be the infrared emiting problem. checkout if the infrared in the remote control is emited well. to see this infrared you can read the article at http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html
good luck
Posted on Mar 14, 2010
SOURCE: tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
Posted on Oct 14, 2011
I have a radioshack gamer 15-133 controller and i want to use it on my ps3, how do i?
Hi! Sorry, but this is not possible. The PS3 uses Bluetooth technology for its controllers and remote controls. The Radioshack Gamer Remote 15-133 is an Infrared (IR) device and will only work with specific units that support IR remote controls(PC, Playstation 2/PS2 and XBOX 360.). Click the TECH SPECS tab on this link for more info.
If you are looking for an affordable universal remote that uses both Bluetooth and IR and will control a PS3, there is only one currently available on the market. It is the INTERLINK VP3700 Universal Infrared / Bluetooth Remote Control for PlayStation 3 and it is available at NewEgg.com among other online retailers. Here is the link for it for more information and to order it. Please note, if you click the Feedback tab, the first review written by TV-Tastic, is my review of it. I have had three of these (the first two destroyed by my then one, now two year-old son who chews rubber buttons off everything) and it is a fantastic remote control especially for the money.
The only other Universal Remote option you have is to purchase a Logitech Harmony Remote Control (minimum $75.00) and the additional Logitech PS3 Adapter for the Harmony Remote controls ($45.00) which involves complicated setup and extra piece of equipment for about $115.00.
Good luck.
May 29, 2011 | Sony Playstation 3 (PS3) Console
Suddenly my remote no longer communicated with the tv. I replaced the batteries in the remote. Still no communication. I can operate the tv with it's buttons, but the remote has no effect. Is there any...
The Infer Red eye sensor is on the tv manual control buttons PCB board.The manual control buttons are on the tv right side on the tv frame bazel,tv facing you.Test all the manual buttons like power button,channels + -,Menu button and input button.All the manual buttons work,than the remote control is problems and the causes.The remotes devices are heaviely depend on it CPU chip.The remote CPU is short or dead,if everythings buttons on the remote completely dead or will only partially functions.The remote is garbage,remote CPU is dying.Try website like Remotes.com to buy an original remote or very close to it.
Jan 03, 2011 | RCA L32HD31 32 in. LCD HDTV
My son spilt water on our remote control so I took the batteries out and put it in rice in the hot water cupboard. Now when I try the buttons, the unit display says Remote Mode 3. Can you suggest...
Please open your remote and let it dry by itselt, You can assist for enhanced drying by using a hair dryer very slightly. Also use a soldering iron to solder lead points of the components, the crystal and the controller IC. after allowing it to dry or repeating the process, switch it on. If there is still a mode indication try to press the power button/mode button while inserting the battery. hope this works. Good day
Aug 12, 2010 | Televison & Video
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
Remote control not working - not batteries, have changed them. Red lcd light is not showing will not turn on using remote control when tv is on standby
you can use buttons on side of tv to turn on
are batteries in right way
to test remote if you have camera on phone switch it on and point remote into camera and you should see flash of light when press any button if not you can get new remote form charles hyde and son ( CHS ) web site you will need model number on remote
Jan 02, 2010 | Samsung LN-S4051D 40 in. LCD Television
Xbox 360 Controllers went out
If the batteries died, the console lost its link to the controller. It must be re-sync'ed.
Please visit this link
http://www.xbox.com/en-AU/support/xbox360/accessories/wirelesscontroller.htm
It explains how to enable/disable wireless controllers.
Hope this helps!
Jan 10, 2009 | Microsoft Xbox 360 Controller
Dino Buddy not responding to r/c
I Replaced the batteries in the dinosaur, because mine did that after only a few hours. when the batteries start to die, only the demo switch works...
I hope this helps!
Nov 29, 2008 | Lillian Vernon Remote Control Dinosaur...
Dead remote
try rebooting the remote control by removing the batteries, then press every button one time, replace the batteries with a fresh set and give it a try. If the remote still fails to work contact remotes.com for
Nov 24, 2008 | Televison & Video
EV-1000B TV Remote
Codes for all Casio TVs are available here http://casio.jp However, they are all in Japanese, so you'll have to run it through Google's translate service.. Hope that helps..
Jan 27, 2008 | Casio EV-1000 10.4 in. LCD Television
LG 32LG30 32 in. LCD HDTV Logo
103 people viewed this question
Ekse
