I'm a computer novice and have just tried to install an internal card reader into my pc - the mother board is a Foxconn 945g7md. There were no instructions with the card reader which I bought on ebay. I found what looked to be the correct lead connetion on the board but when I fired her up the card reader was no recognised. Now I've gone and completly screwed things up by removing the ribbon cable from the power on off button on the font panel to get a better look and I now have 3 2 pin plugs and two single pin plugs and no clue which of the four colourd teminals on the board to connect them to. Please help !
I need driver for my motherboard
Posted on Dec 24, 2008
HI THERE CAN YOU TELL ME WHAT GRAPHIC CARD DRIVERS GO INTO A FOXCONN MOTHERE BOARD TIS IS A EI207 COMPUTER DESK TOP
Hi, you can download the driver here at FOXCONN:
http://www.foxconnsupport.com/download.aspx
Select mainboard
and the mainboard number.
Install this to find the mainboard number:
http://www.piriform.com/speccy/download/standard
Hope this will help you.
Apr 02, 2011 | Foxconn Computers & Internet
I would like to install a internal card reader with a usb port.
Those wires go into an internal USB extension connector - which your motherboard doesn't have. Get a PCI USB card and connect them to it - this way you will also get USB2.
Mar 10, 2010 | Chaintech CT-6OJV2 Motherboard
Propor place to plug in internal multi card reader
Most mother boards have an internal USB connector.
Have a read through *********** board manual it will describe all the connectors. If you don't have the manual you should be able to find it in the ASUS web site.
Also if you look really close at the Mother board and read the little white writing next to the connectors you may spot it.
I just took the lid of my pc to prove it can be done.
Mine is labled USB3 it has a block of 10 pins (male) and one is blank so it is really 9 pins. You mother board will be different to mine but have a look and see what you can find.
Sep 19, 2009 | ASUS M3N72-D nVidia nForce 750a SLI...
Trying too install 4in1 card reader
If its an internal card reader, you should install it in the PCI slot. If it's an external card reader you should plug the card reader into the USB port. I need to know the brand and model of the reader so that I can give you more precise instructions.
Sai.
Mar 01, 2009 | IBM Computers & Internet
Internal memory card reader plug on the MB?
The memory card reader that you have is most likely running on USB, therefore you will need to plug it in to one of the USB headers on your motherboard. They usually are made for 2 USB ports so the connector for USB is 2 rows, but yours is just flat so it will fit anyway.
The USB plug and cable on the motherboard kind of look like this:
http://www.windowsdevcenter.com/windows/2005/02/23/graphics/figure14.jpg
Dec 08, 2008 | EliteGroup 845GV-M3 Motherboard
USB Header
The only way is to purchase a USB Board to install in the PCI slot, but that would be overkill since you PC already has 4) 2.0 USB ports. I would exchange that internal reader for an external reader.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell Dimension 2400 PC Desktop
Internal USB connector
You did not have to unplug the onboard USB ports.
Your OS should see the card reader and set it up, unless you are using Win98 or WinME. I would plug the onboard USB ports, then restart with the new internal card installed.
Sep 26, 2008 | Dell Dimension 4600 PC Desktop
VIDEO CARD
ur mother board dosnt support the AGP card
Nov 27, 2007 | Foxconn P4M800P7MA-RS2 Motherboard
Foxconn motherboard 945g7md
Are you connecting them via SATA or PATA ?
If you are using PATA you'll need to set the jumpers on the drives. One needs to be a master and the other has to be a slave. Normally the Hard drive would be considered the master.
If they are SATA drives go into your bios and make sure the SATA ports are enabled and not in RAID mode.
Nov 16, 2007 | Foxconn (945G7MA-8KS2) Motherboard
Motherboard
Are you trying to install the Dell Media Card Reader? If so then the other end of the ?FlexBay USB cable that plugs into the card reader goes into a small rectangular connector towards the back of the motherboard. Specifically orient as follows; place the computer on its side, the power supply to your left and the front of the computer facing towards you. Starting at the back of the motherboard next to the power supply follow the back edge of the motherboard till you come to the approximate center of the board. About an inch towards you there will be a rectangular connector the FlexBay USB cable end should fit into. If this isn?t the cable from the Dell Media Card Reader let us know and we?ll try to help, otherwise please don?t forget to rate this posting.
Feb 11, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
