Cars & Trucks Logo
Posted on Sep 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wher to locate a neutral safety swich on a toyota corolla automatic 1991model.
Reverse lights not working swich is ok globes r ok so can this be a neutral safety swich problem?
Stephen
Level 3:
Top Expert:
  • Cars & Trucks Master 21,873 Answers
  • Posted on Sep 07, 2012
 Stephen
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6210018
Points
67230
There is a neutral safety switch on cars with automatic transmissions which operates the reverse lights, and a reverse switch on manual transmission models.
You need to check voltage output on which version you have.
5 Related Answers
Anonymous
  • 124 Answers
  • Posted on Mar 11, 2009
SOURCE: no reverse lights, no power to globes, fuse ok.
it's on the transmission
Testimonial: "I know its late in coming but your advice was very helpful, thankyou."
Anonymous
  • 334 Answers
  • Posted on Mar 22, 2009
SOURCE: we need to replace the neutral safety switch on a 1997 Mazda B23
it should near the back of the trans. it will be a two prong plug
Anonymous
  • 11 Answers
  • Posted on May 15, 2009
SOURCE: Need to know where the back up light switch and
off the side of the trans where the shifter is bad switch
macsry2k
  • 64 Answers
  • Posted on Feb 18, 2010
SOURCE: 1990 Toyota Corolla Hatchback no stop lights
check the switch on the break pedal,replace as necessary.
Anonymous
  • 202 Answers
  • Posted on Apr 15, 2010
SOURCE: where is the neutral safety switch on 1998
The neutral satety switch is located at the Right Side Of Gear Selector.
BF wagon eye level brake light is not working have tested globe and globe is working. Also reverse lights not working
If the other brake lights work, probably broken wire. Eye level meaning Suv hatch? If so, the wires tend to break at the rubber boot from the hatch to the body. The reverse lights run threw the neutral safety switch on the transmission. Could be a broken wire, most times it is the switch.
Car only starts in reverse and only drives in neutral
Sounds like a cable to the transmission is not adjusted up right, and/or the neutral safety switch is not adjusted right, if this applies to your Toyota Corolla.
Both reverse lights donot work.Is there a switch that could be bad, and if so where is it located at
If you've checked both light bulbs and they are good, then you are looking for the neutral safety switch. It's connected to the shift lever mechanism somewhere (sorry, I can't say where because I've never looked inside one of these vehicles, much less worked on one).
On automatic transmission models, the neutral safety switch is supposed to keep the starter from running unless in Park or Neutral, as well as turn on the reverse lights in Reverse.
1helpful
1998 Toyota Corolla, automatic. I have trouble starting my car. When the key is engaged to the start position sometimes I just get a click. I have checked the battery w/ a hydrometer and have cleaned...
  1. I tried to find a
    Toyota Corolla Wiring Diagram 1998 |
    If you go to your library you can look for free. Just not sure of location of of neutral safety switch for your year of car. In the back of motor manual is wire diagrams you will find switch there. Also GEO Prism is the same car.
  2. The last time I worked on a Prism it was a 1997 I found a bad wire connection at the shifter. Took 20 minutes to do repair and no parts.
  3. So I would check the switch in your console. Sometime they stick or a wire comes loose. Sometimes a little WD-40 shot to the switch helps.
2answers
Reverse lights inoperable
I would go to local auto parts store and ask them the location by checking on there computer , For example autozone.
1989 Toyota Corolla won't go into drive
check the oil level and refill if need ,type DII oil for automatic transm
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
