Second hand didn't come with a SD card, put a 8GB SD card in and it says CARD ERROR, Doses it need a memory card before it shows immages on the screen or the eye viewfinder as nothing can be seen on either
The GR-DF570 uses SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot it's electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
If you need a manual, you may download a copy here.
SOURCE: "please insert memory card in GZ-MG130U CAMACORDER
You need to tell it in the settings menu that you want to record to the hard drive instead of the SD card.
