Question about Linksys Wireless-G WRT54G Router
I just been able to connect to the internet through my router. I followed your instructions on setting up my router. When I go to connect I now have 2 kellylinks. Although 1 of them has an X next to it. 1. How do I take that off? 2. How do a put a password on my links?
    Problem Solver:
  • 6 Answers
Check this out:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=5449
That site should have all you need for this issue...
Posted on Jan 03, 2009
Error code 80001000A, ZyXEL 660 router. PS can find ip address and connect to internet but as soon as i do anything internet based the connection drops and i get this error code among others but this is...
Go over the instructions at this link carefully http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
If the connection still fails after following these instructions, follow the on-screen instructions to check your settings. You may have to get some info from your ISP and refer to the instructions supplied with your router.
afor more help visit CBR Tech Solutions
Jul 26, 2011 | Sony PlayStation® 3 (60 GB) Console
My router did not come with any software do i need it because i cannot get mine to work
Please reset the router by placing a pin in reset hole and push the pin sslightly, (remember you need to do this when the rrouter is in ON state)
Then connect your router to your computer using ethernet port (this is for configuration) and also connect the ADSL cable.
now open internet explorer and type in //192.168.1.1
Then it will prompt you for username and password
Username: admin
Passsword: password
this username and password is by default.
then configure your router as you need by changing display name, password authentication, MAC registration etc...
If you face problem with connecting internet even following the above steps, then you need to contact ISP(internet service provider) for settings.
Thanks,
Satheesh
Jan 04, 2011 | ASUS RTN10 wireless router
How do i set my ps3 up to get online
Take the ethernet only and attach it to your router. If you are not already using a router for your computer internet connection then if your router has connection software that needs installing for network setup for the router only you run the software on the computer after connecting the router to the PC.
If you use the oruter for your PC connection already then do the following.
  • Connect the Ethernet from the PS3 to the router0
  • On the ps3 Go to settings
  • Go to network settings
  • Go to network connection, select enable
  • Go to Internet connection settings just below internet connection-
  • Push yes when it says you may be disconnected
  • Select wired or wireless
  • For wireless use scan or enter manually
  • Follow on screen instructions.
Once that is set up return to main menu and go to network near the right.
Here is a video instruction:
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
Cable modem internet works when directly plugged into desktop, but when run through the router, no connectivity
Most cable Internet Service Providers (ISP) use a Media Access Control (MAC) Authentication to establish Internet connections for end-users. A MAC address is a unique 48-bit (6-byte) integer that is attached to an Ethernet NIC for each computer. To set-up your Linksys router to a Cable ISP, you have to do MAC Cloning. MAC Cloning is a procedure which enables a router to copy the MAC address of the PC that's registered with the ISP.
To setup a Linksys router with Cable connection you need to perform five steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the Router's LEDs
  4. Configuring a Linksys Router for a Cable Connection
  5. Power Cycling
NOTE: Before proceeding, use the computer that can go online when connected to the modem and follow the steps below.
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your ISP. If it can go online, the PC connected to the modem is the one that's registered with the ISP.
kb4682-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
Once an active Internet connection is established through the modem, connect the modem and the computer to the router by following the instructions below.
After ensuring that you have an active Internet connection, connect the modem to the router's Internet port and the computer to any of the four Ethernet ports. For instructions, click here.
After connecting the devices, check the LEDs by following the instructions below.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router. For instructions, click here.
After checking the router's LEDs, configure the router for cable Internet. For instructions, follow the steps below.
kb4682-002_en.png For Telstra Cable internet users, please contact Telstra to confirm if your internet connection is using DHCP or HB (Heart Beat) signal. There should be no other machine running HB client upon doing this procedure.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE
: If you are using Mac to access the router's web-based setup page, click here. If you forgot your IP address, click here. If you forgot your router's password, click here.
Step 2:
When the router's web-based setup page appears, click the drop-down arrow under the Internet Connection Type field and select Automatic Configuration - DHCP.
(a) If you are NOT using Telstra HB, proceed with DHCP setup.
NOTE: If you are a Telstra Cable internet user and you're using WRT120N, WRT160N v1, WRT320N or WRT610N, please select Telstra Cable.
(b) If you are using Telstra Cable, proceed with the following setup. Obtain your user name and password from Telstra. Please disable any HB client that might have been previously running on the PC after the router is configured.
Step 3:
Click kb4682-005_en.png.
Step 4:
Click MAC Address Clone.
Step 5:
Select Enabled and click Clone My PC's MAC.
Step 6:
Click kb4682-012_en.png.
Step 7:
Click Status. Check the value of the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're not online, perform a power cycle to synchronize the router with the modem. For instructions, click here.
NOTE:
If the Internet IP Address is all zeroes (0.0.0.0) click kb4682-008_en.png first then click kb4682-009_en.png. If the Internet IP Address is still all zeroes (0.0.0.0) perform a power cycle. For instructions, click here.
If the IP Address starts with 192.168.1.xxx or if it has the same first three numbers (octets) as the router's IP address, change the router's LAN IP address to a different LAN segment. For instructions, click here.
Once the router is configured, perform a power cycle. For instructions, follow the steps below.
Power Cycling
Step 1:
Shutdown the computer.
Step 2:
Unplug the router's power cable.
Step 3:
Unplug the Broadband modem's power cable and wait for 30 seconds.
Step 4:
Plug in the Broadband modem's power cable and wait for its lights to appear stable.
Step 5:
Plug in the router's power cable once the modem's lights appear stable.
Step 6:
Power on the computer on and test the Internet connection.
NOTE: If you're not online after performing this procedure, you may need to upgrade the firmware of the router.
Sep 28, 2010 | Linksys Wireless-G WRT54G Router
How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
Dec 05, 2009 | NetGear WGR614 Router
Can I install my belkin router without setup cd?
you may install the belkin router by following the instructions given below.
1. Connect your modem to the internet port of the router.
2. Connect your router to the computer.
3. now reboot the modem and computer.
4. open the router setup page, and click on detect the internet connection.
5. now follow the instructions to install the belkin router. for more information you may follow the instructions given below.
How To Setup Belkin Router Install Belkin Wireless Router Fixotip
Sep 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cann't get my wireless router to work,don't understand how to config the router.
HI helock,
This is a step by step instructions:
Note: It is recommended that you configure the Wireless Router from a wired
computer.
1. Open your web browser, type http://192.168.10.1 in the Address bar, and then press Enter.
2. Enter the User Name and Password, and then click Log In. By default: User Name: admin Password: admin
3. The Wizard will automatically appear. Click Wizard if the Wizard does not automatically appear.
4. Click Next.
5. Select your Time Zone and then click Next.
6. Click Next. Note: Do not change default settings unless it is conflicting with your existing hardware.
7. The TEW-432BRP will attempt to auto detect your Internet connection. Follow the wizard instructions and continue on to step 9.
8. This screen will appear if the TEW-432BRP is unable to auto detect your Internet connection. Configure the settings based on information provided by your ISP.
9. Follow the wizard instructions to complete the configuration. Note: Each Internet Connection type may have different options.
10. Click Next
Note: It is recommended that you enable encryption on the wireless router. Please refer to the User Guide on the User's Guide CD-ROM for information on
setting up encryption on the wireless router. 11. Click Restart. 9. Follow the wizard instructions to complete the configuration. Note: Each Internet Connection
11. Click Restart
12. Click Close.
13. Wait 30 seconds while the router reboots.
14. Verify that the following panel lights are on: LAN, WAN and WLAN.
15. Open up your browser and enter in a URL (e.g. www.trendnet.com) to verify that you have Internet connection.
Your configuration is now complete.
Good Luck,
And don't forget to leave a rating
Thanks
Mark
Sep 14, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Nov 12, 2008 | ASUS WL-530g Router
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Internet connection via wireless router
change the settings in explorer ... Tools- Internet Oprions- Connections
Jun 23, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
20 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
