Question about HP LaserJet 1020 Printer
Priting problem in hp - HP LaserJet 1020 Printer
    President:
  • 2,961 Answers
Could you please advise when you are going to end the session and please rate the session......many thanks Sandrew
Posted on Apr 17, 2007
SOURCE:
Hp 1505n prints only blank pages
Have you replaced the ink cartridges? They go dry after about 100 pages or if you have not used it in a while they will dry up the print heads an not work. If you have not replaced the ink cartridges then you should try that first.
Jan 27, 2015 | HP Office Equipment & Supplies
THE PAPER IS STUCK WHLIE PRITING AND THE ORANGE COLOR INDICATES
it is not picking up the paper properly more then likely bad roller or just dirty clean with lint free cloth & alcohol including the seperator under the roller
Jan 04, 2014 | HP LaserJet 1320 Printer
Stopped priting pdf's...how do i fix? It was
Not printing PDF files is not a problem with the printer if it prints everything else ok. The problem will be in the Adobe acrobat that you have installed, we have seen this type of problem before. This is caused by a corrupted file in the Adobe package. You need to go to Control panel and remove the Acrobat reader and install the latest copy, it is available for free from www.adobe.com You will need to be sure to uninstall the old version before you install the new one.
Buddy
Corporate Computer
May 13, 2010 | HP Photosmart C6180 All-In-One InkJet...
I gave a print job on HP, it was not priting and now it shows Deleting-printing...whta to do
In run window type services.msc and the go to print spooler option just stop and restart the service.on and off the printer it will clear all pending jobs.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 13, 2010 | HP PSC 1315 All-In-One InkJet Printer
I'm trying to print on 5.5'' x 8.5'' cardstock on my hp c4580 printer but it keeps stating paper size mismatch... any suggestions?
Go into your "printer properties" and select "page layout" there you'll see all the size options.Thanks, Dana P.S. You may also try using the sizecode that is prited on the card wrapping for example; Avery 3757, Avery 1270 etc. etc. Thanks Dana
Jan 06, 2010 | HP Photosmart C4580 All-in-One - InkJet...
300 dpi priting
Your printer doesn't have a 300 DPI setting, however, you can select "EconoMode" from the "Preferences" menu after you select "Print". Look for a tab that says "Quality". EconoMode will be lighter than normal 600 DPI printing, thereby saving toner.
Nov 13, 2008 | HP LaserJet 1010 Printer
HP 8500 Color Laser Printer- problem priting reds
the basic causes for this problem is either the foil is bad or weak. secondly the element in the fuser unit doesnt heat properly so try replacing it with a working one n see what happends.
May 28, 2008 | HP LaserJet 8500 Color Printer
HP LaserJet 1020 Printer Logo
29 people viewed this question
Clive
Clive
Thomas F. Schneider
