Question about Canon FAX-L350 Plain Paper Laser
Error message saying " check cover/cart"
My fax machine keep constantly flashing error message saying "check cover/cart", i've checked every where, but could not see what is going on.. pls help !!!
  • Anonymous Jan 03, 2008
    paper jam
  • Anonymous Feb 12, 2008
    I have the same proble with a Canon 2050P
    Problem Solver:
  • 10 Answers
Ok it can be a bunch of things,
1) check the cover that you open to change the cartridge is secure, press down on the top part near the latch that releases it and see if the door switch activated, if you hear the main motor activate then your problem is the locking latch.
2) Change cartridge and /or clean the 2 metal square contacts under the drum, move the drum cover and you can see the 2nd one, use methylated sririts or equivalent and a cloth. Your cartridge may be faulty/old or has leaked toner on the contacts.
If neither of these work you will have to have a visit from a technician as a circuit board may be at fault.
Posted on Jun 11, 2008
Check cover/cart error message
fax toner catridge door is not properly closed. when you close that there is a micro switch that is not going to activate. Please be sure it is closed properly
Nov 25, 2010 | Canon FAX-L350 Plain Paper Laser
I believe there are at least 3 switches that senses if the cover is closed. I aquired one of these and it was throwing this error. I also had the same just happen again and had to trouble shoot as I forgot what the issue was the first time as its been about 8 months. I found my issue to be one of thise sensor switches. Open the cover as if you were going to remove the toner cartridge. Above where the cartridge is the are those 3 switches that I mentioned. you wat the one on the left see the picture its the one with the arrow on a pink piece of paper. There is like a white lever in there it should be in the up postion when cover is open. Take a pen cap that has the shirt clip the cheap bic ones or take a tooth ick and use it to make shure that lever is in th up postion. If it was not in the up postion it should pop up easy. Now try clsing cover let the unit run its test and you should be good to go.53b97c7.jpg
Jan 27, 2010 | Canon LaserClass 2060P Plain Paper Fax
CHECK PRINTER ##330 flashing message
From the message board archives:
Error codes:
## 322 Fuser not heating (Usually Bad Fuser Module)
## 323 Laser Beam detect error
## 324 Laser scanner motor rotation incorrect
## 325 Fan motor inop
## 330 Power Supply (Replace/Repair)
You must turn on error management to have the machine display error codes, otherwise it will just say "CHECK PRINTER".
To turn error management on, enter the following: Press Data registration, #, Set, 00000011, set, stop. Now after the "check printer" message there should be one of the error codes above.
Supposedly, Nation-Wide Repair Service fixes the bad power supplies for $45.00. They can be reached at 800-798-1814. You can also buy one for $148.00 from www.loyal.net I hear. The proper replacement power supply part number for both the LC7000 and LC7500 is HH3-5278 so I am told.
Aug 04, 2009 | Canon LaserCLASS 7500 Plain Paper Fax
Problems with Canon 7500 Laser Class fax
I have Canon 7000 Laser with Error message #330 which said
SET DOCUMENT??? HELP?
Dec 03, 2008 | Canon LaserCLASS 7500 Plain Paper Fax
Lexmark Printer 7170 - Error 1203
Its a Cart error.....one of ur carts have shorted...call 1-800-332-4120...they'll let ya know more...
Apr 28, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error message on Canon Fax Machine 2050P check cover/cart
there are a couple of things did you buy genuine or reman cartridges and check if they are seated properly.
some remans dont work properly so you have to be sure and always get a money back guarantee from the seller
Feb 26, 2008 | Canon FAX-L350 Plain Paper Laser
CANON FAX L360
Hi
We have had the same problem. There are 3 recessed micro switches that are engaged by a flange beneath the top cover. Our problem was caused by one of these switches being jammed down.
Hope this helps.
Aug 17, 2007 | Canon FAX-L360 Plain Paper Laser
Check cover/cart
Two possible solutions remove the top cover (Two screws on top after oepening the cartridge door and two push in black nylon screws in either side). and check the activation lever that activates the cover switch is not riding on top of the switch. Second if this happened your toner cartridge make sure this new cartridge is the correct one for the fax and not a HP modified recycled printer cartridge.
May 31, 2007 | Canon FAX-L350 Plain Paper Laser
Canon laser class 2060p super g3 fax machine
The error keeps flashing and the machine will not work. The error reads, "check cover/cart". We put the cartridge in and out about 10 times and the same error message keeps flashing. the fax machine is still not working. Help!
Apr 24, 2007 | Canon LaserClass 2060P Plain Paper Fax
Canon FAX-L350 Plain Paper Laser Logo
719 people viewed this question
old marine
old marine
