Question about Acer Aspire 5630 Notebook
D2d recovery i cannot run d2d recovery from aspire 5610 4648. I have tried to press alt+F10 during boot up screen, but it doesn't work. Also i couldn't find acer erecovery management in acer empowering management. Any idea how to run d2d recovery, or how to copy from its hidden partition? acer aspire 5630 upgraded from vista home to ultimate
  • Acer Master
  • 4,806 Answers
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Good luck and Merry Christams
Posted on Dec 24, 2008
  • Otilio Albino Mercado Oct 22, 2012
    Thank's for your help i got mi acer back thankyou Lee Hodgson.
Acer Aspire 5920g laptop My computer suddenly crashed during an update coming up with a blue screen. Since then I have tried to use the recovery disks. After successfully loading and showing "windows...
Hi
it may be worth trying this
power up and press the Alt+F10 as soon as possible and this may take you into the factory restore option
where you should have about 2 different options of recovery
just follow the on screen instructions
i hope you can get it sorted
Jun 23, 2011 | Acer Computers & Internet
Factory reset for Aspire one without disk and alt + F10 doesnt work
The disk-to-disk recovery may be disabled preventing the Alt + F10 key sequence running eRecovery. To enable disk-to-disk recovery, you must do the following... (do not have an external monitor attached)
1. activate the BIOS utility by pressing F2 during Power On System Test (while Acer logo displayed)
2. select Main from the categories listed at the top of the screen
3. find D2D Recovery at the bottom of the screen and use F5 and F6 keys to set this value to Enabled
4. exit the BIOS utility and save changes.
5. while the Acer logo is showing, press the Alt key and the F10 key at the same time repeatedly
6. wait as Acer eRecovery starts up then follow onscreen instructions to perform system recovery.
Alternatively to the above, if Windows can be accessed, the recovery can be done by launching Acer eRecovery Management by running the program from the Acer Empowering Technology program group in the Start menu.
Mar 22, 2011 | Acer Aspire One PC Notebook
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have 1recovery **** named aspire 5610 dvd2 should i have a dvd1 disk also
go to http://www.sysresccd.org/Download
download the iso and burn it to a cd.
boot your computer with it
read the explanations coming up on the screen and when you see that you can choose how to start, type "wizard"
choose the top choice (auto)
when it starts right click on the desktop and start GPARTED.
one of the discs will be marked as "boot"
right click the disc called "recovery" (or the one that is not marked as boot).
choose manage flags
set it to Boot.
press apply on top (not always needed tho)
in the left picture (the one that opened from the start)
type reboot
remove the cd when you see the acer logo again.
the acer recovery manger should start.
May 29, 2009 | Acer Aspire 5610-4648 Notebook
System recovery not working.
hello try this website http://www.thinktechno.com/2008/02/09/how-to-fix-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
lets try this first and if it don't work we will try something else
just copy and paste in your address barr
hope this helps bob
Mar 24, 2009 | Acer Aspire 9300-3716 Notebook
Hello, I have Acer Aspire 5710 Notebook Comes with witndows Vista, i installled Windows XP on it now i need to Restore it on factory default settings. but when i press ALT + F10 on system stratup it does...
Press Alt and tap F10 only when the acer screen appears.
If this does not work and open the recovery program then is it possible that you formated over the driver and partition when you loaded XP?
If not the make sure that D2D recovery is enabled in the bios settings. You can check this by pressing F2 on boot and going into bios.
Nov 30, 2008 | Computers & Internet
Erecovery
Check that it is enabled in the bios
Press F2 when you boot and go into bios, make sure that D2D recovery is enabled. Then save the changes and exit, to run the recovery program you need to press Alt and tap F10 on boot when the manufacturers screen appears.
I hope this helps
Nov 14, 2008 | Acer Aspire 5315 Notebook
D2d recovery
you can not use erecovery and d2d if your don't have the hidden d21 partition on your harddisk. and since you have replaced your harddisk you don't have it anymore.
mail to compurepair and see if he can fix it..
rate me if you want.
CS.
Apr 08, 2008 | Acer Aspire 5630 Notebook
D2d recovery
Is the d2d erecovery function enabled in the bios?
To check, activate the BIOS utility, press <F2> during the POST; while the notebook PC logo is being displayed.
To enable D2D recovery ard disk recovery), select Main from the categories listed at the top of the screen.
Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled.
That should allow you to use the F10 function key to activate D2D.
* Note: D2D e-recovery is not in Acer Empowering Management.
AEM is a power management utility that supports ACPI (advanced configuration and power interface) which allows for maximum power conservation and maximum performance. (Managed by the windows OS)
Jan 04, 2008 | Computers & Internet
Acer Aspire 5630 Notebook Logo
695 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
