Question about Marantz ZR6001SP
Marantz Error Code "SUM1" SR8000 Receiver
Just in time for the holidays! The receiver will normally work properly for a few minutes, then the audio shuts off and the display flashes "ERROR SUM 1." How many years should you expect from a receiver like this anyway? Has anyone out there run into this problem?
SOURCE: What does this Error Message mean?
hello AuburnCE, After 4 years of joy my Marantz SR8200 receiver also shows this message from time to time - after 1h of operation or so. Then it is hanging (like a PC ;o). Taking it of from the electricity network for a moment resolves the problem until the next POW 05 hang usually a fiew days later. I brought the receiver to an authorized Marantz maintenance and repair center twice now and they were not able to reproduce the error. They said this has directly or indirectly to do with the power supply unit. They also called marantz. For me it appears that this is not an internal receiver problem IN MY CASE. I think I there might be a relationship to zapping on my Topfield SAT receiver via power supply network as the connection is optical. Or my dimmerunit for the light. Unfortunately I do not have a separate electric circuit for Audio/Video and all other electrical devices. and dimmer units are well known to cause problems in the power supply chain - e.g. like noise in your audio package. Please note: the experts told me: Check POW 05 can have other (receiver internal) causes also. Above is just my suspicion 8as a non-expert) for my case . Regards, Fred
Posted on Sep 11, 2007
SOURCE: no audio
I Have Problem with Marantz SR5500. An accessories, a remote controller has ben broken . I would like to replace. If I could where would I can get this remote controller
Posted on Oct 22, 2008
  • 133 Answers
SOURCE: marantz sr5001 has pcm light flashing
I suppose pcm light means that the pcm mode is turned on (pcm meaning pulse code modulation), in other words, the unit was switched to digital signal, so if the digital rca or optical TV input on your reciever is not connected to anything, then you're not getting any signal into the reciever in digital mode. You probably just need to switch the unit back to analog mode (see if there is a button that says something like digital/analog, pcm/analog, optical/coax or similar, try pressing it, see if there is any change).
I might just be totally wrong on this, however, probably the best way to learn what happened is to read the user manual if you do have it (see what the pcm light signals for and check any chapters inside the manual related to that topic).
good luck
3rq8 (Triarcuate)
Posted on Jul 25, 2009
  • 5603 Answers
SOURCE: My Marantz PMD 661 digtial audio recorder is
ALC Automatic Level Control
In other words, an audio compressor which reduces the level when the level gets too much.
Look up "audio compression" with Google for a complete treatise how it works.
Posted on Oct 28, 2009
Testimonial: "Thanks fredy2, I haven't seen that one before and I don't know why it's telling me that, but I'll take your word for it. I appreciate your help."
satavlad
  • 405 Answers
SOURCE: error code 'CHECK E2P IF'
Water damage is the worst. It could damage the boards beyond repairability. It will take a professional to determined, if your unit can be saved
Posted on Nov 28, 2009
Receiver turns off after it has played for a few minutes. I reset the light and it will run again for a while and then turns off.
There are a few possible causes:
1. Your receiver is broken.
2. One of your speakers has a short in it.
To tell which, disconnect all your speakers at the back of your Marantz, and turn it on. Does it stay on? If yes, then check your speaker wires and speakers one at a time for normal volume...
Dec 11, 2015 | Marantz Sr 6001 Receiver
My Marantz sr 4001 receiver has no output. Is
There is no fuses for the speakers. Check setup. If the receiver has 7.1 channel input try to connect a source there so you can check output (amp) section and the speakers.
Jul 18, 2010 | Marantz SR4001
Need to give a FULL RESET in a MARANTZ SR5004 RECEIVER
Switch off the unit. Then hold down Sorround, Exit, Memory & Clear buttons all together and then switch on the power. This should work.
Jan 26, 2010 | Marantz Audio Players & Recorders
Error code 'CHECK E2P IF'
Nov 28, 2009 | Marantz Audio Players & Recorders
What is the error POW 5 on a marantz sr 7500
I have a POW 5 failure on a marantz sr 7500. Anybody know how to fix?
Jun 02, 2009 | Marantz SR-7400 Receiver
Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Feb 11, 2009 | Marantz SR-5200 Receiver
May 29, 2007 | Marantz ZR6001SP
Marantz ZR6001SP Logo
125 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
