This is an error code dealing with the toner auger motor being bound up. Has the waste toner message been on for along time and the waste toner bottle not being emptied. Sometimes the waste toner counter has been reset several times without the bottle being emptied. This will cause the waste toner to back up in the auger mechanism. Thsi will have to be taken apart ( very tedious job ) and the toner removed from the tube. The auger spring and even some gears may have to be replaced. I've never had to replace the motor on any copier yet. Good Luck.
SOURCE: sir ; i have a canon ir6570 machine,it was
this problem due to an over current has been detected in the toner feed motor,you must check the connector or replace the motor
SOURCE: E0004 on Canon NP6050
it is a SSR,heater 1 or 2 ,or thermal switch error.
Try to reset, follow this procedure.
SERVICE MODE
E004 SSR O FUSER WON´T SHUT OFF
To reset this code use simulation 401
SERVICE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck CE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck
SOURCE: I am getting an error code E0004 on my np8530 copier
there are a motor sensor does not work properly
the waste toner bottle is stuck int he hopper assembly
try removing the toner bottle and reseating it
if it doesn't work then you blew a fuse on the dc controller board
