Question about Kitchen Ranges
OUR AMANA CONVECTION "BIG OVEN" 4.66 CU. FT. HAS AN ERROR DISPLAY "F1". BURNERS ALL WORK, OVEN DOES NOT. WE HAD A POWER OUTAGE WHILE COOKING A HAM IN THE OVEN, POWER CAME BACK ON AND OVEN DID NOT WORK. MOD #ACF7225AC SER #11019438CN
  • 1,031 Answers
F1 error shows that your electronic range control(ERC) has failed you need to rebuild or replace it.hope this helps
Posted on Dec 24, 2008
  • 15,935 Answers
For the F1, thats means you will need to replace that control board
  • blueextc3221
    blueextc3221 Dec 24, 2008
    This is for a Whirlpool F1 code, but that code means the same on virtually all brands. Try this:
    You have either a bad ERC (clock) or a bad touch pad. Here is the procedure for determining your problem.
    1. Disconnect power to stove
    2. Gain access to the back of the clock (electronic range control or ERC).
    3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
    4. Make sure everything is clear and will not short out when power is turned back on.
    5. Turn power back on to stove.
    6. Watch for codes and listen for the beep.
    7. If you get a code and beep, replace the ERC.
    8. If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
      NOTE: Some models incorporate the touch pad and the clock as one part.
What happens when you turn on the pilot light on a Capital Gas Cooktop and cook with it on
you have just triggered an exothermic reaction of light hydrocarbons and oxygen as a result of introducing an external heat source trigger. Which could possibly result in the cooking of some dinner. Yum.
No worries Barbara, you have done no damage. Unless dinner burned....
Feb 27, 2016 | capital Precision GCR486G 48" Pro-Style...
Cooking with convection oven
You do not have to remove the turn table, but I use the metal rack when cooking with convention.
Apr 15, 2014 | GE Profile PEB1590 1.5 Cu. Ft., 1000W,...
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
Burners do not turn down to selected temp and food burns
I wish I had good things to say about GE but I don't. Probably the burner control is no good. Contact GE and get support due to the fact somebody can get hurt.
Nov 16, 2013 | GE Profile PS968 30" Slide-in Electric...
Broiler shuts off
Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
Jan 18, 2013 | Maytag Gemini MGT8655X 30" Freestanding...
The burner in question is the center back the indicator light stays on even in off mode
u may have a bad switch.. if the light stays on while all burners are off.. u will have to check each switch one by one to get the right one..
Dec 12, 2012 | DCS Professional RDU486GLL 48" Pro-Style...
Child error appeard/ turnd power off now se appears how to start again
SE is a error code, the problem is with the keypad control board, there is a short in the membrane of the keypad.
Apr 06, 2012 | Samsung Amana 1.6 cu. ft. Over-The-Range...
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Kitchen Ranges Logo
170 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
