Check on the MTU settings of ur 2wire.
This are the steps to see what ur MTU setting is:
>connect a computer to the 2wire
>open Internet Explorer, Safari or Firefox
>enter this on the address bar: gateway.2wire.net/management
>enter ur system password (in case u forget this, click on i forgot my password to get a hint)
>look for Advance in the column on the left
>click on configure services
>on the bottom, u shud see the MTU number
** i searched online and accdg to xbox tech support, ur MTU should be in the range of 1364 to 1500 **
>click on submit after u change the setting
just in case youve entered the correct MTU setting but it still does not work, u might need to contact either xbox or ur internet service provider.
Keep me posted on this one.
Once you have all the wireless
settings of the router, you are ready to connect the play station or the
x-box to the wireless network.
X-BOX
On the x-box you will need to
connect to the wireless network now.
Open the
main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox
and open System Settings.
2. Select Network Settings, Configure
Network.
3.
On
the Basic Settings tab, select your wireless settings.
4. Select
the name (SSID) of your wireless network. If your router isn't
broadcasting your network's name, select Specify Unlisted Network and
enter the name.
5.
If
your network has wireless security, enter your WEP or WPA key.
6. Try to
connect to Xbox LIVE again.
Trouble connecting to the
internet on X-box ,Play station or WII ?
You can
try to reduce the MTU settings on the router. if the MTU on the router
is set to 1500 then change the MTU to 1365. Also you will need to open
the ports on the router.
For
X-box port numbers are - 53, 80-88, 3074 .
I have the same problem with my 2wire 2701hg-s not supporting my xbox live. I checked my MTU and its at 1500... now what?
