Question about Kitchen Ranges
Setting Timer. I don't know how to set the timer on my hotpoint stove, and i have no manual.
    President:
  • 373 Answers
There might be three buttons under the clock
One button is for timer, one for stovetop preset and the other for oven preset.Press the second button for setting the clock.
awaiting your comments
happy holidays and good luck
Posted on Dec 24, 2008
No solution but do not know how to set the time on mine
also would like know how to turn clock off
thanks
jah_10@hotmail.com
Posted on Jul 09, 2009
    President:
  • 842 Answers
This has been a nightmare. I just found my manual though. To set the time of day: Hold down the 2 far left buttons at the same tome (Thats the buttons with a pocture of a bell and a steaming dish). While holding down these buttons, use the + and - buttons to adjust the time. (Note, this is a 24 hour clock with no option to change to 12 hour). If you make a mistake and press a wrong button, then the manual tells you to turn the cooker off at the mains and wait a minute or two (for the clock memory to clear) before powering on and starting again
Posted on Jan 23, 2009
  • Chris Hall
    Chris Hall Jan 23, 2009
    Forgot to say, if you need a full set of instructions on all the timer functions, see the note I posted in response to a question by "Plummers" which has further details.
2 Suggested Answers
  • 26 Answers
SOURCE: Setting Clock on Hotpoint Stove
push in on the center one I think
Posted on Mar 10, 2008
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Hotpoint stove timer replacement
what color wires are on the new timer?
Apr 07, 2008 | Ovens
T8845pv
You have 120Volt Intermatic sprinkler timer with 24Volt output.
Copy following link for setting sprinkler timer:
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
Copy following link for wiring Intermatic sprinkler timer:
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Add a comment
lllllllllllll
May 25, 2013 | Intermatic T8845PV - Sprinkler-Irrigation...
Hotpoint BD32 timer does not work
The timer may be defective.
Dec 23, 2017 | Ovens
I bought a home which has the timer . But I don't know how to set the timer. Timing is now from 8 pm to 10 pm, I need to change it, how?
More information is needed about timer.
Check out following options, or add a comment any time.
Adding a comment send email and I will answer.
1) Open following link for setting analog timers.
Applies to in-wall and plug-in type analog timers.
http://waterheatertimer.org/How-to-set-timers.html
2) For a programmable timer, a comment and describe timer buttons, and include if timer is in-wall or plug-in.
3) Open following link to see Intermatic, Woods, and GE timers plug-in, in-wall, and box timers, including indoor and outdoor:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
Sep 08, 2011 | Hardware & Accessories
Does not heat
Turn it on Just joking you need to put more details than that is it electric or gas does it have a make or model is the timer set or is it stuck on auto if its a manual timer turn it on to say 10 minutes does the oven work then if so you need to turn it to the manual setting Regards Geoff Stove Recyclers
May 28, 2011 | Ovens
Stove is fine but the oven does not heat.
Possible faulty element. What about the clock/timer? Is it on the right setting? It should be in manual mode. If the timer is okay it will generally be an element or a faulty connection at the element.
Feb 09, 2011 | GE Cooktops
Double oven will not switch on hotpoint ew91
Press 2 buttons at the same time on the the left of the the timer unit, and then press one otjher button on right of timer unit, this should bring it off auto setting.
Dec 25, 2008 | Miele Novotronic H350-2B Electric Single...
Mar 10, 2008 | Kitchen Ranges
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
314 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
