Question about E-Machines etower 633id PC Desktop
I have an etower 633 id PC with 64 MB of RAM. It runs pretty slow. I was wondering what was the max amount of RAM that I could upgrade to? And if I would have to flash the BIOS in order to upgrade to the max amount?
  • 136 Answers
Your machine is a little on the old side and can only hold a maximum of 256mb. That is 128mb chip per slot. Crucial does not sell it so your best bet would be an ebay search. you do not have to flash your bios to use the max ram, but you should check to see if there are other reasons to do so.
Posted on Dec 24, 2008
Slow loading,game cutting off
Try adding more RAM
Adding more ram will boot applications / games quicker
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
You should always ask or get working pairs in a ram upgrade some ram modules wont work together even if they are of the same brand and type ie: DDR ,DDR 3
Checking Amount of RAM
Click on "My Computer" and select "Properties" using right-click in the Explorer window.
This will open "Systems Properties."
Click on the "General" tab.
Here you can view the physical memory installed on your computer.
The amount indicated is the total RAM installed on your computer.
RAM is usually 32 MB, 64 MB or 128 MB in older PC versions.
Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
Check the usage.
To know the currently used RAM (based on programs you are running), open the taskbar or press "Ctrl + Alt + Del" to open a pop-up window. Click on "Task Manager."
Click the "Performance" tab.
You can view the amount of memory currently used by each program running on your PC.
Mar 18, 2014 | Computers & Internet
I have hopelessly slow windows xp, Dell Dimension 2400, 2.52GHz, 384 MB of RAM [2002, owned since 2004] Have deleted all invisible startups, run a clean virus scan, run cleanup/cleandisk, disk...
It makes no wonder that the machines slow with only having 384MB of RAM installed.
If you were to max out the memory capacity of the machine which i suspect is DDR SDRAM and probably has a maximum of 2GB as this would make the machine much faster that what it is now.
384MB of RAM is just not good enough to run XP properly these days.
If the machine is still in good working order (apart from it being slow) then you could upgrade the RAM.
Regards.
Jul 19, 2010 | Dell Dimension 2400 PC Desktop
Hi, my Asus a8m has 512 mb of ram. I'm considering buying a macbook, but wondering if it would be worth upgrading to 1 or 2 mb of ram and having a professional 'clean out' my asus. Would it be worth it?...
max supported memory is 2GB (2x1GB sticks replacing your current memory). Yes, it'd be worth it to add more memory of you were keeping the machine, otherwise restore it to original configuration and sell it "as is". Don't get a professional, just used your ASUSes restore option to set it back to factory configuration.
Feb 07, 2010 | ASUS A8M Notebook
I incerased the ram from 128 to 256 but it still
Dude!
It seems that video card on the computer is consuming the rest of 64 MB memory.
Get into the CMOS of the computer and reduce the video card memory.
Hope, it helps.
Jul 16, 2009 | E-Machines etower 766id PC Desktop
I have a Satellite 2405-S221 and I was wondering if the max memory i can install is 512K, is there a way to update the bios, or ANYTHING to increase that amount to at least 1 gig??
Toshiba Satellite 2405-S221 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 256 MB (removable) of Memory. You can upgrade your Toshiba Satellite 2405-S221 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 256 MB (removable) standard Memory installed.
In short.... yeah, 512k is the max.
Doesn't appear to a bios limitation. It is a hardware issue that is limiting the amount.
Jan 24, 2009 | Toshiba 2405-S221 Notebook
Etower 633id runs very slow. Only has 64MB of RAM.
Normally upgrading bios does not require flashing the bios. But in order to find out the max amount you can upgrade too requires some info off the motherboard. You need to get the model number off the board to look up the info
Dec 24, 2008 | E-Machines etower 633id PC Desktop
Sluggish slow performance and bad keys
Sounds like both machines may have spyware / malware on them. I would download Malwarebytes Anti-malware scanner, it is a free download; can be found here: http://www.malwarebytes.org/mbam.php
Paying for the program gives you "real time" protection, but it is fully operational without paying the only difference is no real time protection is offered.
This will get rid of a lot of the junk that often gets installed on a computer over time.
The other thing to look at is upgrading your RAM, a lot of computers are sold with only 256 MB of RAM on XP machines and 2 GB on Vista machines; these are the bare min required to run Windows; you should max out the RAM for your machine; depending upon the age of the machine you should be able to add anywhere from 2 GB to 4 GB of RAM, really old machines may have a cap limit of 512 MB or 768 MB check with your manufacture before purchasing. Some motherboards will support more than 4 GB but unless you are running XP 64 bit or a 64 bit version of Vista; the 32 bit OS is only going to see a max of 4 GB in XP Home Edition it seems to only see a max of 3 GB.
Dec 08, 2008 | Dell Inspiron 6000 Notebook
Installing Pentium III processor on etower 433i
windows 2000 is good for pentium 4 not 3 you can not upgrade the prossesor without the mothboard and ram
Sep 28, 2008 | E-Machines etower 433i PC Desktop
How to upgrade a Dell Latitude CPX - Intel P3 500-650 laptop
I have a CPX H500GT. To get it to run XP Pro to run right, max out the ram. And get a larger harddrive. Xp uses a substantial amount of space.
Sep 22, 2008 | Dell Latitude CPX Notebook
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
E-Machines etower 633id PC Desktop Logo
125 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
