Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
Barely extracts anything from Francis Francis X1 - not flowing
My FF X1 is only 1 year old and just recently it's stopped working. The espresso does not flow out like it used to...drips out maybe 1 tsp at most. I de-scaled, no change. Prior I was using Black Cat espresso grind, and switched to Starbucks espresso grind. The starbucks worked normal for a handful of cups, so I'm thinking that the espresso type is not the problem. Any suggestions?
  • 10 Answers
SOURCE: francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Posted on Apr 01, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
Posted on May 21, 2009
SOURCE: I recentlty bought a Francis X1 (2000 model). I
There are two different handles made for this unit (I own an X1 and have both). Both of these handles have baskets.
First - The pod handle has a basket area that is very shallow, about 1/3 of an inch deep and the basket has very small holes.
Second - The handle for loose grounds came with two baskets, one for a single dose, and one for a double dose. Both removable baskets have the very small holes for the espresso to drip through.
You must have a basket in the handle in order to use the machine. If you try to make espresso without a basket, you'll just make a mess. Besides, the machine will never be able build enough pressure to extract espresso from the grounds.
Search the net (ebay?) for francis francis x1 handle.
Good luck
  • 1089 Answers
SOURCE: francis francis X1---the steam nozzles won't work,
HI Unscrew the chrome tip from the wand. Then check the wand tube for a plug. Insert a paper clip into the wand tip to see if there is a restriction.
Posted on Feb 07, 2010
SOURCE: I bought a second hand Francis Francis X1 Espresso
Perhaps the heating element is broken. Does it heat up at all? If not, the steamer won't work and there will be nothing for the gauge to register.
Posted on Feb 09, 2010
Drip drawer for white FF X1
HI
Try Illy.com
877-469-4559
They should be able to point you in the right direction
Nov 11, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis X1 pump replacement.
http://www.craystone.com/francis/francisfrancisfaq.html
for spares Espresso Parts, Tel: 0870 3851531
Oct 20, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis X1 Gasket broken
Hello Salmonp,
You can contact Empire Fulfillment at 877-855-4540 for all of your Francis Francis machine needs. The are the authorized service center for Illy cafe and the FF machines.
Aug 05, 2009 | FrancisFrancis! X1 Espresso Machine
Francis Francis X1 blowing thru ESE pod
Check the group head shower, make sure it does not have any defects(cracks, scratches or unusually large holes).
May 30, 2009 | FrancisFrancis! X1 - Stainless Steel...
May 21, 2009 | FrancisFrancis! X1 - Stainless Steel...
Good luck
Feb 24, 2009 | FrancisFrancis! X1 - Stainless Steel...
I am looking for user guide / user manual of the Francis Francis X1. Thanks
Go to this site www.redmonkeycoffee.co.uk select expresso machines then FF X1 you will see a link to download manual
Dec 29, 2008 | FrancisFrancis! X1 - Stainless Steel...
FRANCIS FRANCIS X1
You want to be careful using some parts that may ship from the UK. You want to be sure the parts that they ship to you are for a standard 120V machine and not a 220V. This may be the difference you are seeing in the temp gauge.
Jun 17, 2008 | FrancisFrancis! X1 - Stainless Steel...
Low temperature
I had the francis francis examined.  It is indeed the boiler, a $200 fix if you could get the part.  Francis Francis X1 is now a brick!
Dec 19, 2007 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis! x1 leaking
Well, to state the obvious, you should call Francis! Francis! at 1-877-854-4141 and ship it to them for repair. It's unlikely you can perform a fix yourself. Have you tried opening the machine up? I got PDFs of diagrams and part lists, which I obtained by calling them at the number quoted above. Good luck! Stephen
Dec 13, 2007 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
61 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
