Motorola MTR XV2100 (56 Channels) 2-Way Radio Logo
Posted on Dec 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NEED TO CHANGE FREQENCY ON RADIO?
CANT FIND MANUAL FOR MOTOROLA XTN SERIES.MODELXV2100
Anonymous
Level 2:
  • Expert 123 Answers
  • Posted on Dec 24, 2008
Anonymous
Expert
Level 2:
Answers
123
Questions
Helped
67089
Points
145
2answers
Motorola Manuals Download
You will need a programming cable and computer software from Motorola.
Program manual page
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwi41fis6eLJAhUF5CYKHTgFAFQQFggdMAA&url=https%3A%2F%2Fwww.buytwowayradios.com%2FProducts%2FMotorola%2Fmanuals%2FXTN-series-manual.pdf&usg=AFQjCNFIOd86CBLE45ZNgdfTwEtH6ZhRsA&cad=rja
How to set channels to be thesame on all motorola xtn series radios
Here is a link to the user guide for the XTN style radio. http://www.123radios.com/manuals/xtnmanual.pdf
Programming instructions begin on page 18. You will need to set the frequency and interference eliminator code (PL code) the same on all the radios.
When you enter programming mode, you can use the menu button to walk you through the various options you can program.
Best regards.
Were can i find software for 448 xtn motorola radios?
Hello Harry,
I checked the manual for this 2 way radio, and I don't think there is anything like "software" in this context.
The firmware has been hardcoded to the hardware itself.
If you could explain your issue in detail, perhaps I can be of some help.
You can refer to this manual if you want: http://www.scribd.com/doc/15685467/Motorola-Xtn-Series-Userguide
If that's not the problem, then let me know. I'll be glad to help you out.
Please rate this solution if it helps you.
I need to fix the frequency to match my other motorola XTN series radio model #XV2600 to my new motorola RDM2070d radio
Here is a link to the CP100 user manual, it is the sister radio2.gif to the XTN, and programs the same way. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Refer to the bottom of page 20 to get started programming2.gif.
Basically you hold in the PTT and the MON button while turning the radio on. Continue to hold them in until it stops making noise. This puts you in programming mode, and you can use the menu button and the + and - to walk you through reprogramming the radio.
We do not know specifically how your RDM2070d radio is programmed. You would need to know this to program your XTN to match. However, a good educated guess would be to start with Blue dot and Green dot frequencies off of the frequency chart in the user manual listed above. An educated guess on the code setting would be "zero" or "off".
Your radio dealer who supplied the RDM2070d radios to your corporation should be able to tell you the exact frequency and code; or read-out the radio.
Info on user manual
Here is the link you need: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/XTN_Series_User_Manual_E.pdf
You will find the explanation for programming the radio in the manual.
1helpful
No user manual for the RDV2080d
Here is a link to the programming software http://www.radioserviceincorporated.com/files/1935423/uploaded/RDX_Series_CPS_R01-00.zip
And here is a link to the user guide http://www.astracomm.com/media/pdf/RDX_Display.pdf
The RDV2080 VHF with display would be compatible with the XTN series radios which have a model name starting with XV, as in VHF. Typically the RDV2080 ships on the default frequencies found in the XV2600. So if you have not changed your XTN frequencies/PL code they may match out of the box.
On a sidenote: The Motorola CP110 VHF is also compatible. It is an industrial version of the RDX radio. It has a few more channel capability and a replaceable antenna. It looks just like the RDX models, and it is the replacement radio for the CP100 and/or XTN.
All of the above mentioned models are repairable.
Parts for XTN Series Motorola Radio
Call us here at eradiostore 800-872-2627, we can help.
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
