Question about Sony Handycam DCR-SR80 HD Camcorder
Night Shot Plus will not turn off
I havea sony handycam dcr-sr80. When filming outside the night shot plus still stays on. I see how I can turn on and off Super NS Plus but for some reason NS Plus is on when not required. I am unable to see anything in the view finder as I believe the exposure is set to night time and allowing too much light in. I have read the manual and played with the menu. Is there away to "reboot" or adjust the exposure setting to turn off NS Plus when outside
  • 5 Answers
SOURCE: Blank screen
Hi: Check and see if there is an X as in escape out of the Menu Mode. If there is no X,then look fo OK. Good Luck. zeffy57.
Posted on May 29, 2007
  • 36 Answers
SOURCE: Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Posted on Sep 13, 2007
welcomejee
  • 10594 Answers
SOURCE: Can not set the camcorder to Super Nightshot Plus mode
To enable " Super Night Shot " option, find slide switch at top of camera as shown in picture...Regards,
Posted on Aug 21, 2008
SOURCE: sony handycam dcr hc 42 red lcd screen
Just call 1-800-222-7669 Sony Support. They will send you pre-UPS label and you mail your camcorder to Sony support. They will replace the LCD View finder for free. I did it about a year ago.
Posted on Sep 10, 2008
mistersony
  • 320 Answers
SOURCE: my lcd and view finder are unable to show subject
The problem you are having is called a "stuck iris" Inside the lens are two thin plastic sheets that slide over one another that limit the amount of light that comes into the lens. In some Sony camcorders, the motor or "actuator" that drives the iris, or moves the two sheets which are the iris opened and closed. The actuators sometimes leak oil onto the plastic sheets causing them to stick, so the light coming into the lens is stuck at one level. Some technicians will recommend lens replacement (expensive) but many times the iris assembly can be removed from the lens and cleaned. Try to find a service shop that will clean the iris rather than replacing the lens.
Posted on Nov 12, 2008
I cannot find in the manual how to set the camera to film a theaterperformance?
PROBABLY BECAUSE IT IS ALMOST IMPOSSBLE!
Live theater and lighting presents one of the greatest challenges for any camera. The dynamic range is going to be incredible. To help compress this range you should combine an ND filer with a bit of extra gain using one of the night shot modes.
Nov 12, 2013 | Sony Handycam DCR-SR82 Camcorder
Sony Handycam DCR SX33E
Sony Handycam DCR-SX33
I shot some video and when I try to play it this message comes up :
"No applicable files available"...what does that mean
The display screen has a grey sort of sideways broken chain on each little film I shot
Any info or guidance most welcomed
Thanks
Tony Swindon
Oct 04, 2010 | Cameras
No camera image on screen while recording on sony DCR-DVD7 sound is recorded, playback from previous recordings are fine
If it is a white screen and you have been recording in bright daylight you may have the Night Plus slider on.
Jul 04, 2010 | Sony Handycam DCR-DVD7 DVD Camcorder
I have a SCR-HC40 handy cam. All of a sudden the infrared stays on even when night plus is off?
Correct model # is DCRHC40. please try to reset the Camcorder by pressing the reset button located near the handstrap using a sharp pointed object and try. If the issue persists, the camcorder will require service
Sep 26, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony handycam DCR-DVD 105 stuck on Night recording
Below is an image to find Night Shot switch to OFF this function.
Jan 26, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
DCR-SR42_Nightshot
If you shot the videos in dark with night shot on. There is no way to convert them to look like day. But if you use a editing program like Sony Vegas you would be able to tweek the video to look simi normal.
Jan 08, 2009 | Sony Handycam DCR-SR42 Camcorder
Aug 21, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony handycam camcorder lcd screen white and no displays
For the "all white screen" in daylight problem, check to make sure the "Nightshot Plus" slider switch is set on "off."
Jan 05, 2008 | Video Cameras
Screen Dim Records as if the lights are low
check the night shot plus button. put it off and try
Dec 14, 2007 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony Handycam  DCR-SR80 HD Camcorder Logo
176 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
