Question about Nikon D70s Digital Camera
I have a straight white line showing in images (small dot at end)
I have a straight white line apearing in images - it is not the lense as it appears even when I change lenses.
  • 24 Answers
You have a defective imaging chip.
Posted on Dec 24, 2008
Why am I getting pictures with curved edges edges
Hi Ian
What you are suffering is something called barrel distortion which causes images to appear spherised or "inflated". Barrel distortion is associated with wide angle lenses and typically occurs at the wide end of a zoom lens. The use of converters often amplifies the effect. It is most visible in images with perfectly straight lines, especially when they are close to the edge of the image frame
the way to solve it is to try not use the end of the of the zoom of your lens. Above 20 mm you should be fine. If this is not possible then you can correct the effect in programmes like Photoshop
Hope this helps
May 09, 2014 | Sony Cameras
In camera optics, where is the aperture located? At the focal point? If so, why doesn't the aperature size ( f/stop) change the image sise on the film/sensor?
The aperture is located somewhere within the body of the lens, but not at the focal point of the lens. Lenses are designed so that changing the aperture changes the amount of light passing through the lens without affecting the image size. Some lenses are designed so that other changes within the lens affect the image size---that's what zoom lenses do.
Jan 12, 2011 | Cameras
The left side of the picture is distorted with a double image. The right side is fine. As things such as the stock symbols on CNBC scroll across from right to left on the screen, they start out looking...
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
You can pay somebody to do it, but may cost you like 100.00 or do it yourself, it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Hope this will help in solving the problem....
Jan 12, 2011 | Hitachi 51GWX20B 51" Rear Projection...
Both lenses have developed straight horizontal lines in the bottom half of the lenses. They have just appeared and have not been scratched. The glasses were purchased about 2.5 years ago.
hi
i think these problem usally occour when the glasses get old and the lenses of sun glasses get reached with the sun rays which is one of the cause for it .so i request you to replace it
If you are satisfied with my answer please vote three thumbs up.Thank you
Nov 17, 2010 | Electric Eyeware Hoy Sunglasses
Hi, When i turn on my camera attached with my 18-135mm lens, it says F-- . I've tried change with another lens, then it became normal and it seems like no problem at all. What is the problem actually...
Hi Norhid. There may be no problem at all. If your camera body is in shutter priority and your lense's aperture ring is turned to any setting besides its widest, the body and lense will not synch. See if you can find an orange aperture setting on your lense's ring, and a white dot on the lense alongside the aperture ring. Mount your 18-135 and line up the orange aperture number with the white dot and see if everything works. If that doesn't help, try switching the exposure modes you're shooting in. Hope this helps.
Oct 06, 2010 | Nikon Cameras
My camera is not letting light in when I take a
Do you have the aperture ring on your lenses set to "A"?
Feb 01, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Lines on the screen
pls try to chek if lense r working perfectly
May 05, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Lines on scanned images
if the lense has dust on it how do i clean
Oct 29, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
Nikon Coolpix l6
With the power off, hold the camera in your palm and smack the front of the camera on your leg or arm. You might have to smack it a few time to get it to work. It has to do with the camera CDD lense (shuttle) being stuck. By smacking it around, it will free up the lense. Being extra gentle with it though. It worked for me. Hope this help.
Sep 30, 2007 | Nikon COOLPIX S6 Digital Camera
Lines appearing in scanned images
it is due to following reasons 1. dust on lense 2. connector problem 3. laser lense gone 4. missalingment
Sep 28, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
Nikon D70s Digital Camera Logo
83 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
