Question about Dell Inspiron 6400 Notebook
No bootable device
Then I hit f-5, and get:
error code-0141
msg. error code 2000-0141
msg. no drive found
    Scholar:
  • 108 Answers
Error Code 0141 means no drive detected.
If that's your problem then you should take out the harddrive out and try it on another laptop or buy an external enclosure.
You can get them for $10
If it won't run on another computer that means the harddrive is bad but if it does run then it means you have a serious issue within the laptop componants.
Posted on Dec 24, 2008
    Master:
  • 413 Answers
You will need to call the manufacturer and probably have a new drive installed. When i researched this code it came up with a lot of dell forums and everyone recommended to have the drive replaced since this means it is probably about o go out for good. Still i would check in the bios and make sure the drives are enabled and in the correct boot sequence also check and see if there are any non bootable disks in the drives/removable memory
Not booting
What is the error message you are receiving upon powering up the device?
Is the error msg No Bootable Device or Drive?
If this is an older computer with a hard drive, the hard drive may have gone bad, which is leading to the error of no bootable device/drive.
Jul 25, 2016 | Computers & Internet
My dell 5125 indicates internal hard disk drive not found. it asked me to reseat the drive...than it indicates no bootable devices- i'm strike F1 to retry to boot and F2 for setup utility....nothing...
Try accessing setup utility and verify there if it still recognizes your hard drive, if not then that means your hard drive had crashed. If you have important files on the drive, you can try to recover it by going to a local service provider and have your files recovered, and of course you have to get a new hard drive for your dell.
Sep 13, 2010 | Computers & Internet
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
Dell error code 0141
Error code 0141. Msg: Error code 2000-0141. Msg: No drive detected.
This is caused by the intel chipset overheating.
Your drive is usually ok, but the chip controlling the drive is too hot to function properly. Try blowing your CPU fan out with compressed air, then start using a laptop cooler to keep it cool and this problem should go away.
Apr 05, 2010 | Dell Inspiron 1525 Laptop
Error 0141 msg:error code 2000-0141
The hard drive has failed. If you're in warranty, contact Dell for a warranty replacement of the drive - it's a customer-replaceable part.
If you're out of warranty, look on ebay for a good deal on a brand new hard drive for your Dell Inspiron 1525
Nov 09, 2009 | Dell Inspiron 1525 Notebook
Juice got spilled on my laptop, now when it starts i get an error code 0141 No drive detected. what should i do now? Error 0141 Msg Code 2000-0141 No drive detected at start up : no bootable devices Help...
you should have stopped using it first...get the battery out and have it dry in an airconditioned room for several days...I know you can't afford that..water is a sort of conductor and it short-circuits sensitive electronics.
Aug 11, 2009 | Computers & Internet
No bootable device found.try reseating hard drive,error code 0141
Make sure you fixed the HDD properly..In some cases you need to push a little harder. See if any pins had been bent, if so straighten it, without breaking it.
Jun 07, 2009 | Dell Inspiron 1525 Notebook
Can't start windows: Hard Drive - No drive detected
The laptop cannot see/detect the hard drive. This means the hard drive is faulty or it needs reaeating.
Remove the hard drive and inserting again, then reboot the laptop, if it still cannot detect the hard drive then it is faulty.
You need to purchase a new one and install Windows on the new hard drive.
Mar 14, 2009 | Dell Inspiron B120 Notebook
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
Dell Inspiron 6400 Notebook Logo
906 people viewed this question
Alun Cox
