Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Display message not covered in the manual
My machine is displaying the message AL08 but this fault is not covered in the manual
  • christine764 Dec 31, 2008
    Many thanks for your reply. This message was only displayed once & has not re-appeared. Also, I have run the machine a few times since & the water is hot. So, here's hoping all Ok. Thanks
  • 157 Answers
Heater
Posted on Dec 31, 2008
Top loading Gorenje WT 52113, it stops a few minutes into the washing cycle, an error message comes up on the small digital display, looks like d02?
This washer only has f fail code, they recommend you contact svc person for repair. Fail code for F02: F2 Door lock fault detected The door lock on the washing machine has been detected as faulty or failed to engage correctly.
  • Check that the washing machine door has been closed correctly and is engaging the door lock correctly
  • Check wiring to door lock
  • Check door lock
  • Check wiring at control module or timer
Aug 12, 2016 | Washing Machines
What is Technical Fault 51?
The most common reason for this code is :-
F51 error is caused by a faulty or blocked heater pressure switch. It is not a job for an unqualified person.
"The program is interrupted and the drain pump is operated. The display shows Technical fault F51. Call Service Department. The buzzer is activated for 2 minutes. "
Apr 14, 2015 | Washing Machines
Problem detected with this unit on the display won't function
Did it "seem" unbalanced, or "sound" unbalanced. Can you turn the unit on and then get the fault message, or is system locked in fault? You can download the manual at:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=WPGT9360EPL
Look through the troubleshooting section and see if it can answer your questions. Also, warranty information is located in the manual as well ;-)
Apr 02, 2013 | Washing Machines
Hello, my hotpoint dishwasher is giving me al08 error. I have already replaced the heating element but the fault still exist.What else could it be?
Sorry but you have actually posted on the washing machine forum ;-0)
You would be better off re-posting this onto the dishwasher forum where someone, hopefully, will be able to answer!
Good luck,
John C
Mar 01, 2011 | Washing Machines
The digital display jumps programmes wont empty or spin
Take the toe kick off of the machine. Reach in and up to the right. There is a "manual" which covers error codes and possible remedies but not much more. Hope your "manual" is still there.
G.
Apr 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
Fisher & Paykel washer IW712: fault code 105
Fault codes sheet is located under the dryer control cover.
Fault Code 105 Communications Error Time Out - I&A
Communications failure between the sensor module and display module. (loose wire). 1).Visually check the contacts on the RAST (edge) connector at each end on the harness between the sensor and the display module. 2). Replace sensor module and/or display module and/or harness.
Nov 09, 2007 | Washing Machines
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
310 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
