Question about Samsung HCN653W 65" Rear Projection Television
Descending curved line on screen
There is a curved line that falls from the top of the screen & takes up about 1/4 of the screen. There is an appearance of blue letters and numbers underneath any TV text (as if those blue characters are shadowing the actual screen text). When I use my DVD/VCR combo & select a channel that I do not have access to, the entire screen is naturally blue but the area above the curved line is shaded in black. Due to this malfunction, obviously the picture quality has become a bit distorted. I already tried perfect focus & I'm not too proficient in working with the convergence feature. What can I do to correct this problem? Is it a matter of replacing a bulb? Is there a solution to this problem? Please help. Thanks in advance.
    Champion:
  • 217 Answers
If the tv has a portal on the side open it up and make sure the screen is not out of it's track, don't set anything on top of the set it could make it happen also
Posted on Apr 30, 2007
SOURCE:
Hello, my blackberry curve 8520 has a horizontal
I have the same problem, but it's a vertical white line.  I have a BB Curve 8310.  From what I've researched on the web, it seems the LCD screen wud have to be replaced.
Feb 20, 2010 | RIM BlackBerry Curve 8520 Smartphone
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Blue curved line at top of screen and yellow curved line at botto
Do you by chance have any speakers sitting on top of the tv or right beside it. Speakers are unshielded and will cause this effect.
Feb 03, 2009 | Televison & Video
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dark vertical lines on tv screen
looks like lcd panel is off.the cost is abit less of anew tv!
Jul 07, 2008 | Televison & Video
Toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Feb 09, 2008 | Televison & Video
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Samsung HCN653W 65" Rear Projection Television Logo
159 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
