Question about GE DSXH47EGWW Electric Dryer
Dryer no heat
Dryer turn on with no heat then shuts it self off
    Novelist:
  • 163 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
Control board Part # 134484212
Posted on May 14, 2012
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
I have a older Maytag gas dryer DG612. The igniter comes on the gas lights, runs for about 5 seconds then shuts off. The process repets its self over and over again. It is trying to start but shuts off the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 16, 2010 | Maytag MDG7600AW Gas Dryer
The unit will turn on but there is no heat. i have cleaned the unit and checked for blockage. the unit will run and won't shut its self off.
No heat is usually caused be either by a bad heating element or a plugged vent. Many vents also have a flap inside of them that close when the dryer needs to heat up and opens when it needs to cool off.
Also when a dryer doesn't shut off, it is usually due to a fault timer.
If you have a bad control board which is fairly common, you will have more than one component that is not operating correctly.
Jun 14, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Dryer turns on there is heat but shuts off. I
Modern dryers have safety switches that should turn off the heat if there is a problem. The motor may not be working or the drive belt may be broken.
Jan 25, 2010 | Dryers
MODEL GE/GQ9858J dryer runs about 5 min. or
dryer was working with codes for 5 to 10 min now there is no heat at all but will stay running?
Aug 02, 2009 | Whirlpool Dryers
Gas dryer seems to be overheating
The first and easy thing to check is the vent going out of the house if it is restricted or cloged it will over heat and shut off check that first
Mar 28, 2009 | Maytag MDG6400 Atlantis Gas Dryer
Electric dryer heat coil off mid cycle
You have 3 thermostats. By the description of the problem it sounds like it needs a new high limit thermostat. All 3 thermostats and the heating coil can be checked with an ohm meter. Also check the ground on the heating coil. It could be grounding it's self out.
Jan 16, 2009 | Kenmore 62602 Electric Dryer
GE DSXH47EGWW Electric Dryer Logo
335 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
