Question about Canon imageRUNNER 400S Copier
CANON GP405 ERROR E014 PROBLEM
When I start cpying error E014 appears instructing me to switch main switch OFF and ON. I have tried several times without any improvement. What is the cause of this error and how solve the problem
When I start my machine the error code e014 appears and machine do not run.
Posted on Nov 04, 2011
  • 168 Answers
That is an error code for the fuser drive..... probably the lower fuser roller bearings. you can try spraying wd-40 when its cool on the lower roller bearings on either side if it seems to work it probably will be just temporary..
Posted on Dec 24, 2008
  1. Fixing unit jamp. Cheak the lower rolar bering.
  2. Fixing Drive Motor.
  3. Mother bord.
  4. Composite power supply.
Posted on Mar 04, 2011
.HAVEN'T USED 10D FOR A LONG LONG TIME AND
Here are a few things to try:
1. Remove the main battery and the small backup battery (CR2025) from the battery compartment. Charge your main battery and put both batteries back in once your main battery has been charged. Sitting without batteries will give the camera a chance to reset itself.
2. You may have a bad CF card. Try starting your camera without a CF card or use another.
3. Try reloading the firmware (camera's operating system) using this link Canon. http://web.canon.jp/imaging/EOS10D/10D_firmware-e.html
Be careful to follow instructions exactly as restarting the camera in the middle of a firmware update will brick it and you will need to send it back to Canon for repair.
Hope that helps,
Bax
Oct 11, 2011 | Canon EOS 10D 35mm SLR Camera
How to fix error code E014, it shows on screen switch main power off and on then E014, but I turned off and on many time , it stay like that
If I remember correctly..... A E014 mean that the main drive is not spining freely. Most of the time the fuser unit is not turning smoothly. Have you tried to spin the fuser unit? If so is it smooh or tight? Have you looked in the fuser to see if the web is wraped around the upper fuser roller? Or is the lower fusing roller cut? If that all looks OK > it is the fuser drive gears (on the front of the fuser) are locked up... You may have to take the two white gears off and clean & lubract / oil the shafts.... Good Luck > there is not a way to reset the code until it is fixed
Feb 04, 2011 | Canon imageRUNNER 400S Copier
When I start my computer appears CPI Express
Reinstall the Video Driver once and check if the same issue persists. Open the Task Manager and check the name of the Process that is running for CPI express
Jul 04, 2010 | Toshiba Qosmio F25-AV205 Notebook
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
Epson aculaser c1900 error code e014
Error code 014 indicates that the cooling fan on the power supply board is not operating when the printer is switched on. Does n't explain the poor print quality though. I suspect it is a worn 2nd BTR roller (the black foam coloured roller inside the rear door). To check this send a coloured print through and press hard against the rear door during printing. If the print quality improves then it is a worn roller, if it doesn't let us know and we'll try something else.
Please take a moment to rate this solution. Thanks.
Mar 10, 2009 | Epson AcuLaser C1900 Printer
Error e014 on canon gp 605
I THINK E014 IS FUSER UNIT MOTOR.REPLACE MOTOR.DO NOT FORGET TO RATE SOLUTION.BY MIAN JEE
Feb 22, 2009 | Office Equipment & Supplies
Iam getting error code E010,E014
A E010 & E014 have to do with the main motor drive. You may have a drum blade that has flipped or it could be that the center screw that locks the drum to the drum shaft is loose ( just tighting screw- you can also get blank copies as well. The E014 deals with the fixing unit, you have to make sure it is spinnig freely. It could be that the lower pick off claws have dug in to the lower fixing roller, or the ball bears are siezed or the web is rapped around the upper fixing roller or a bushing is broken or it may be to much pressure is on the UFR from the web... Just a few ideas.. Good Luck
Nov 06, 2008 | Canon Office Equipment & Supplies
Canon imageRUNNER 400S Copier Logo
1,736 people viewed this question
old marine
old marine
