Question about SanDisk Sansa m250 MP3 Player
Sansa m250 not powering on
Hi, I tried to use my sansa m250 playe after a couple of weeks. It did not power on. Initialy i thought it was a battery issue. So i changed the battery and checked again. It still did not power on. After that i connected it to the PC and it started working. As soon as i removed the usb it powers down automatically. What could be the problem. Has any one of you faced such a issue. Also if u guys can give me the support url for this product it would be great. Thanks Vikram Lagu
  • 1 more comment
  • kitthy Mar 09, 2008
    pls anybody help
  • Lorka Mar 13, 2008
    PC does not recognize my SanDisk Sansa m250 MP3 player as a drive.
    Connection to PC turns MP3 player on, and then nothing happens.
    Files are not displayed on the MP3 player as well.
  • jesse slayvac Jun 01, 2008
    it only goes on when hooked up to the pc.but all it says even then is "USB CONNECTED MTP" and when unplugged it immidiatly goes off
Thanks
Karan Singh
Posted on Feb 10, 2008
  • 3 Answers
OH wow this is the same problem i am having. I hadn't used it for a few weeks too. and now it is doing the same thing yours is....???? tells me it probably isn't a *individual player thing*...God i hope we get a solution. I use mine for powerwalking. At least i can coonect to the PC get it started up and go. But how frustrating when i am flying etc. can't take it with me then!! Looks like i'll be getting a new one. it will be my 3rd in less than a year!!!
Posted on Apr 24, 2007
Sandisk sansa m250 mp3 player problem
try formatting it or updating the firmware
Feb 11, 2010 | SanDisk Sansa m250 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Cant find driver online for sansa m250 id like to put music on it, i have win xp....
Win XP does not need an addl driver - it should just plug and play; check Sansa's driver page as a precaution:
http://www.sandisk.com/DriverDownload/driverList.asp
Jun 09, 2008 | SanDisk Sansa m250 MP3 Player
Sansa Sandisk M250
Hi XX,
Thanks for asking me to be your Tech Buddy.
For Sansa units, a couple of things you can try:
a. do a soft reset - press on the Power/Menu for 15 seconds;
b. do a full settings reset - Main Menu/Settings/Reset All;
c. do a Format - Main Menu/Settings/Format but all in the internal memory will be erased.
If for some reason your version/model do not have a format option, please refer to this solution posted by another expert, computerrep.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 06, 2008 | SanDisk Sansa m250 MP3 Player
How can I get my Sansa m250 to power on??
If your Sansa Connect won’t start check to make sure the device is
charged and the hold switch is in the unlocked position. If the device still
will not start, you may need to run the Sansa Device Recovery application.
With a copy of the Sansa Device Recovery application installed on a PC,
you can connect your to the device via the USB cable to the PC, and
restore the device software to an uncorrupted state. However, all of your
subscription settings and content will be removed from the device.
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
or google the sansa connect recovery tool
I have Sanso m250 2.0gb mobel. Logo screen is appearing when i power on after that i am unable to play the mp3 songs or play FM Radio etc..
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. I do not know if this will work on other Sansa m200 type .mp3 players. You can start over with your playlists. This has worked for me.
Dec 23, 2007 | SanDisk Sansa m250 MP3 Player
Sansa - sandisk m250 troubleshooting
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstall the battery without pushing any further buttons.
  2. Plug the Sansa into a computer, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC Specific storage" file.
This should hard reset the Sansa m250. This solution has worked for me.
Dec 20, 2007 | SanDisk Sansa m250 MP3 Player
My Sansa m250 does not appear!!
Try this ... Press Menu button, Go to Settings, Go to USB, Highlight MSC and press the white button. Now, connect it back to your computer and see in Explorer if it picks it up as a separate drive labeled SANSA.
Also, make sure you are loading songs into a separate folder. I named my folder TUNES.
Nov 29, 2007 | SanDisk Sansa m250 MP3 Player
Sansa m250 freeses on power up
throw it against the wall because sandisk is aware of this problem and does nothing about it... they should replace them for free but they don't... race condition in that firmware screws the player up...
Jun 17, 2007 | SanDisk Sansa m250 MP3 Player
My sansa m250 says "not enough space for Music DB Please Free 8MB".. when...
I received the same problem, I thought I had done a Sync by mistake and had used of all the space. I had to re-format the player and start over.
Jan 27, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
57 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
