Question about Plantronics 510SL Headset Voyager Bluetooth Wireless Lifter Combo Package Headset
The blue light on the top of the unit doesn't come on...
This is a new unit that I am just setting up. After a couple hours of charging the the headset is displaying a blue light while the cradle is continuing to not have a light on. There is a flashing red light and a constant yellow light. Would I simply need to wait until the yellow light goes out and then the blue light will come on?
Thanks for your help... Margie
Peter Denton
  • 16 Answers
SOURCE: Plantronics voyager 500a
With these units, if the earpiece battery is allowed to run down, it will switch off. When the earpiece turns off the base station starts to search for it, which is indicated by the flashing red power light. Also the blue light on the top of the base will turn off. The first step, which you have already done, is to charge the earpiece. Next, hold down the little black button that is on top of the earpiece for about 5 seconds. You should get a slow flashing blue light on the mic boom. Wait for about 10-20 seconds and the base should automatically find the earpiece. The red power light on the base will be steady and the blue light on top of the base will come on.
Posted on Oct 03, 2008
Peter Denton
  • 16 Answers
SOURCE: plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Posted on Nov 05, 2008
SOURCE: Bluetooth is flashing red and blue
sounds like your in pairing mode ... use your phone to search for the device ... when its found the system will ask you for a code ... enter "0000"
Posted on Jan 08, 2009
  • 32 Answers
SOURCE: headset does not flash red/blue so I can pair it with my phone
To get it into pairing mode (flashing red and blue) turn the headset off.  Hold the main button down until the light goes red and then off.  Then push and hold that same button and keep holding it even after the blue light comes on.  It will now go into pairing mode, flashing red and blue.  Set your cell phone to find it and it should work.
Posted on May 22, 2009
SOURCE: Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
Posted on May 07, 2010
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
I cannot find a replacement battery for the blue parrot B250-XT 3.7v 230mAH. My head set stopped working. I tried recharging it. The light indicates that it is charged but when I press the on button it...
The batteries for the B250-XT and Xpressway are not user-changeable. If you believe that your headset requires a new battery, please contact Technical Support at 800-742-8588.
Aug 28, 2011 | VXI Corporation Blueparrott B250-XT...
The blue and red light doesn't. Come on at all
First, make sure to charge the unit for a few hours. Next, try pairing with the following link:
How to Pair Plantronics Voyager Pro Bluetooth Headset
If it still doesn't enter pairing mode, the unit is defective and needs to be replaced. It comes with a 12 month warranty. Contact your supplier to receive a replacement.
Good Luck from Headsets Direct!
Apr 27, 2011 | Plantronics Voyager PRO Bluetooth Headset
I installed a new 12-cell battery yesterday and can't get the lap top to power up today. There is a slight flicker of blue light on the charging icon (thinderbolt) when I hit the on button.
try unplugging the battery and starting up with just the cord if that works charge the battery for 16 hours for a initial charge if after the 16 hour charge it does not work call the company because you have a bad battery
Dec 02, 2009 | HP Pavilion dv6000z Notebook
I was given a garmin ique 3600 but i plug it in how do i know its charging
It lights up on top. Then the litle battery icon will show with a lightning bolt.
Nov 20, 2009 | Garmin iQue 3600 GPS Receiver
The blue light on my base unit is on but the headset does not app
Unplug the unit -- Then grab the ear peice, and slide off the battery, wipe off the metal prongs ...leave apart for a couple minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the battery to charge. But this should solve your issue.
Aug 29, 2009 | GN Netcom GN 9350 Wireless Headset
GN 9350 Headset won't charge, blue light remains off I tried the solution of placing the headset on the charging cradle, then pressing both phone/USB button simultaneously The headset light...
Unplug the unit, then take the ear piece and slide the battery off .... When you have the battery detached from the ear piece, wipe off the metal prongs, leave it off for a few minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the unit to be charged. That should take care of the issue.
Jun 21, 2009 | GN Netcom GN 9350 Wireless Headset
For Zen M: Blue ligth on continuously with new battery
have you tried doing a Software re-set. (Hold the On/Off button in the On position whilst pressing the Reset button). Then try re-charging. The device will take about 10-15mins before it responds if the battery is completely flat.
Jan 22, 2009 | Creative Labs ZEN Vision:M Digital Media...
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Radio Communications Logo
Top Plantronics Radio Communications Experts
skiffy99
skiffy99
Level 1 Expert
shaun taylor
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
