Question about HP Officejet 6310 All-In-One InkJet Printer
6310 interface with latop with vista
I have the USB properly connected and my laptop said that it successffully loaded the driver; however, when I hit the scan button, it says there is "no connection"
  • 33 Answers
Is it scanning from the standalone machine ?
if yes .. then uninstall the driver using the disk ?
Explore the Software CD Contents and look for "uninstall L4" (which will be located under a yellow folder named CCC)..and double left click on the "uninstall L4" icon...
make sure u unplug the printer from the computer before u run the uninstaller..
once the software is uninstalled ..reboot the system and install again..
Posted on Dec 24, 2008
Recently I upgrade my 400sd4 to 512 memory, anew hard drive 160gb and loaded in vista home premium. Now my wireless adapetr linksys wireless-b causes the computer to freeze and not load. I tried loading...
I suspect your problem is with the drivers for that WiFi-B card. You didn't say what the make & model is of that card, but most manufacturers have not updated their older products for Vista (older WiFi-B & not-so-old WiFi-G cards included). If you're trying to force some older Windows 2000 or XP drivers to work in Vista, you're bound to have issues. You may need to replace that card with a new WiFi device that has drivers for Vista. If that device is USB 2.0, you'll need a USB 2.0 PCMCIA card because the built-in USB ports are only 1.1. You should be aware that this laptop supports only 1 PCMCIA card.
There are other problems with your setup, as the hardware of this system just is not up to running Windows Vista well. First, the graphics hardware does not support the shading instructions and DirectX 9.0+ needed for the "Aero" interface included with the Home Premium version of Vista. Second, Vista might run with only 512MB of RAM (the max this laptop will support), but not well; it really "likes" around 2GB of RAM or more. Third, the BIOS of this system (even the latest and last update) does not support 48-bit LBA (logical block addressing), so it can only "see" hard drives up to 137GB. Any hard drive capacity above that will not be seen by the system, and may result in some drive corruption. At best, you will not have use of the full capacity of that 160GB drive.
Lastly, even if you can get all of the Vista drivers needed for this system's chipset and such to work properly, you will probably not be pleased with this system's inability to run the "Aero" interface, or with the performance limitations when running under Vista. My suggestion would be to remove Vista and install Windows XP. That is what this system was designed for, and all the appropriate drivers are readily available -- possibly including the correct one for your Wireless-B card.
Jan 30, 2011 | Gateway 400SD4 Notebook
Need driver for panasonic nv-gs27
You might be connecting the Camcorder using USB interface. The drivers for USB streaming is not available for Vista and Windows 7..
Operating System also matters..
If you're using XP OS, you can install the driver from supplied CD and use Windows Movie Maker to transfer the recordings using USB interface.
Vista, Windows 7 - You need to use i.LINK or A/V interface to transfer the recording. When using i.LINK with Vista, you can use the Picture Motion Browser software.
I think this will definitely help you to connect the Camcorder..
Jan 05, 2011 | Panasonic NV-GS27 Mini DV Digital...
USB device detection in Gateway Laptop
It sounds like your laptop BUS (usb power) does not have enough power to power the interface between the two. I had a couple of devices that did that. You may have to buy a SELF powered USB HUB in order to make them connect. The self powered usb will get it's power from and A/C wall outlet and not the laptop. You will connect you device to hub and hub to laptop.
Sep 18, 2009 | Gateway GT5432 Refurbished AMD Desktop...
Can no longer fax or scan
got to control panel and uninstall all the applications and drivers related to your printer in the machine running vista. Then place the printer installation CD came with your printer in the CD drive. Now just connect your printer to machine and switch it on. Vista should display new Hardware connected or any other sound alert acknowledging that printer is connected to your machine. If it prompts for driver installation, select it to search for drivers automatically. Before that make sure that your printer installation cd is in drive. Vista will automatically search for the drivers and installs it. If it's not, then the cd came with your printer may not have drivers for vista. go to HP website and download driver for vista and install it.
Jul 28, 2009 | HP Officejet 6310 All-In-One InkJet...
Will HP Officejet 6310 install/function properly on Windows Vista
Yes, indeed it will.
Make sure you download the suitable drivers here:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=1119598
Jun 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Need postscript printer driver for vista
Here is the full software, just install it as postscript printer during setup.
HP Officejet and Photosmart Full Feature Software and Drivers
Unplug the printer USB befoare starting setup.
Here is also general download page for 6310:
» HP Officejet 6310 All-in-One Printer » HP Officejet 6310xi All-in-One Printer
Oct 26, 2008 | HP Officejet 6310 All-In-One InkJet...
My samsung till won't talk to my lap top
Windows Vista is the last operating system that you would want to use for legacy hardware -legacy being anything that requires a usb to rs 232c adaptor. Scripts required to make this work would drive you to an abacus. If you need to have a cash register input on a permanent basis I would recommend another operating system, even a real old computer would be easier to interface or you could use the modem output of the Samsung to connect to your laptop in a LAN configuration maybe even with a null modem connection. Vista will drive you crazy with permission denials with cries of cyber-sodomy with an analog interface directly connected. The Samsung 755 has a USB interface but since you don't have the correct input for your laptop it will be far easier to use the cash register an an old (cheap) computer with an RS 232 interface and connect it to your laptop with a wired or wireless LAN configuration. Those USB to DB9 0r DB25 or PS2 adaptors still cannot match the speed parameters that the laptop US Host controller would ever find acceptable. Windows XP or 2000 might be a consideration but Vista is already neurotic enough without interfaces it was not designed to accomodate. I hope this will save you from alot of frustration. respectfully, Steve Medley
Oct 14, 2008 | Casio Parts Cash Register PC Desktop
HP Officejet 6310 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
